SD Memory Card Sizes for Automotive Devices
An automotive device can use the minimum/maximum (max) card size listed below under the device series.
Important Information:
A device may draw maps more slowly when using a card with a larger capacity if there are too many files and/or large files on the card.
A microSD card with at least 16 GB of space must be used when updating the maps on a device.
See Using a 64 GB microSD/SD Memory Card or Larger for devices below compatible with 64 GB microSD memory cards or larger.
Garmin Express™ will only install a map update to a memory card if there is not enough space on the internal storage of the device.
Maps cannot be moved from the device to a memory card manually.
Instructions on where to insert the microSD card can be found in your Device's Owner's Manual.
Some devices have 2 microSD card slots: one for map data and one for dash cam storage.
microSD cards can be purchased from Garmin or other retailers. Garmin offers the 16 GB microSD Class 10 Card with SD Adapter for purchase.
NOTE: Garmin Dash Cam devices require a Class 10 card.
The card may need to be formatted to work in the device.
For instructions, go to the Support Center and enter the product name or the serial number of your device.
Once your device is selected enter “Formatting Camera SD Card" ” in the search field.
Select Your Device Series From This List:
Camper and RV GPS Navigators
Model | Maximum Capacity | Card Type | Class |
Camper 660LMT | RV 660LMT Camper 760 | RV 760 Camper 770LMT-D | RV 770LMT-S | 32 GB | microSD | Class 2 to 10 |
Camper 780 & Traffic | RV 780 & Traffic | 256 GB | microSD | Class 2 to 10 |
Camper 785 | RV 785 (Map SD card slot) | 256 GB | microSD | Class 2 to 10 |
Camper 785 | RV 785 (Camera SD card slot) | 64 GB | microSD | Class 10 |
Camper 795 | RV 795 | 256 GB | microSD | Class 4 to 10 |
CamperCam 795 with Built-in Dash Cam | RVcam 795 RV Navigator with Built-in Dash Cam (Map SD card slot) | 512 GB | microSD | Class 4 to 10 |
CamperCam 795 with Built-in Dash Cam | RVcam 795 with Built-in Dash Cam (Camera SD card slot) | 512 GB | microSD | Class 10 |
Camper 890 | RV 890 Camper 1090 | RV 1090 | 256 GB | microSD | Class 2 to 10 |
Camper 895 | RV 895 Camper 1095 | RV 1095 | 256 GB | microSD | Class 2 to 10 |
Click Below for Video Instructions on Where to Insert your Device's microSD card:
Camper 795 and RV 795
Camper 890, RV 890, Camper 1090, and RV 1090
Camper 895, RV 895, Camper, 1095 and RV 1095
CamperCam 795 and RVcam 795
dēzl and dēzlCam GPS Navigators
dēzl™ 560 LMT GPS navigator dēzl™ 570 LMT GPS navigator dēzl™ 760 LMT GPS navigator dēzl™ 770LMTHD GPS navigator | 32 GB | microSD | Class 2 to 10 |
dēzl™ 580 LMT-S GPS navigator dēzl™ 780LMT-S GPS navigator | 64 GB | microSD | Class 2 to 10 |
dēzlCam™ LMTHD and dēzlCam™ 785 LMT-S GPS navigators with camera (Map SD card slot) | 64 GB | microSD | Class 2 to 10 |
dēzlCam™ LMTHD and dēzlCam™ 785 LMT-S GPS navigators with camera (Camera SD card slot) | 64 GB | microSD | Class 10 for dēzlCam 785 LMT-S Class 4 or higher for dēzlCam LMTHD |
dēzl™ OTR500 GPS navigator dēzl™ LGV700 and dēzl™ OTR700 GPS navigators | 32 GB | microSD | Class 2 to 10 |
dēzl™ LGV800 and dēzl™ OTR800 GPS navigators dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators | 256 GB | microSD | Class 2 to 10 |
dēzl™ LGV610 and dēzl™ OTR610 GPS navigators dēzl™ LGV710 and dēzl™ OTR710 GPS navigators dēzl™ LGV810 and dēzl™ OTR810 GPS navigators dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators | 256 GB | microSD | Class 2 to 10 |
dēzl™ LGV620 and dēzl™ OTR620 GPS navigators dēzl™ LGV720 and dēzl™ OTR720 GPS navigators dēzl™ LGV820 and dēzl™ OTR820 GPS navigators dēzl™ LGV1020 and dēzl™ OTR1020 GPS navigators | 256 GB | microSD | Class 2 to 10 |
dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera (Map SD card slot) | 512 GB | microSD | Class 4 to 10 |
dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera (Camera SD card slot | 512 GB | microSD | Class 10 |
dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera (Map SD card slot) | 512 GB | microSD | Class 4 to 10 |
dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera (Camera SD card slot | 512 GB | microSD | Class 10 |
dēzlCam LGV710 and dēzlCam OTR710
dēzlCam LGV725 and dēzlCam OTR725
dēzlCam 785 LMT-S and dēzl 780
dēzlCam LMTHD
dēzl LGV610, dēzl OTR610, dēzl LGV710, dēzl OTR710
dēzl LGV620, dēzl OTR620, dēzl LGV720, dēzl OTR720
dēzl LGV800, dēzl OTR800, dēzl LGV1000, and dēzl OTR1000
dēzl LGV810, dēzl OTR810, dēzl LGV1010, and dēzl OTR1010
dēzl LGV820, dēzl OTR820, dēzl LGV1020, and dēzl OTR1020
Garmin Catalyst Driving Performance Optimizer
Model | Minimum Capacity | Maximum Capacity | Card Type | Class |
Garmin Catalyst™ Driving Performance Optimizer | 32 GB | 256 GB | 256 GB | Class 10 |
Garmin fleet management
Garmin fleet™ 770 | Garmin fleet™ 780 | Garmin fleet™ 790 management | 32 GB | microSD | Class 2 to 10 |
Garmin Fleet 780, 790 (Camera SD card slot) | 128 GB | microSD | Class 10 |
Garmin Dash Cam
- For devices below compatible with 64 GB microSD/SD Memory Cards or larger: Using a 64 GB microSD/SD Memory Card or Larger.
- For most Garmin Dash Cams: SD Memory Card Compatibility for Garmin Dash Cams.
- SD Memory Card Compatibility for Garmin Dash Cam 10, Garmin Dash Cam™ 20, Garmin Dash Cam™ 30, and Garmin Dash Cam™ 35
- SD Memory Card Compatibility for Garmin Dash Cam™ 45 and Garmin Dash Cam™ 65W.
- SD Memory Card Compatibility for the Garmin Dash Cam™ 54 and Garmin Dash Cam™ 55.
Garmin Dash Cam™ 10 Garmin Dash Cam™ 20 | 4 GB | 32 GB | microSD | Class 10 |
Garmin Dash Cam™ 30 Garmin Dash Cam™ 35 | 4 GB | 64 GB | microSD | Class 10 |
Garmin Dash Cam™ 45 Garmin Dash Cam™ 54 Garmin Dash Cam™ 55 Garmin Dash Cam™ 65W | 4 GB | 64 GB | microSD | Class 10 |
Garmin Dash Cam™ 46 Garmin Dash Cam™ 47 Garmin Dash Cam™ 56 Garmin Dash Cam™ 57 Garmin Dash Cam™ 66W Garmin Dash Cam™ 67W Garmin Dash Cam™ X110 Garmin Dash Cam™ X210 Garmin Dash Cam™ X310 Garmin Dash Cam™ Mini Garmin Dash Cam™ Mini 2 Garmin Dah Cam™ Mini 3 Garmin Dash Cam™ Live Garmin Dash Cam™ Tandem | 8 GB | 512 GB | microSD microSDHC microSDXC | Class 10 or higher |
Garmin Drive, Garmin DriveAssist, Garmin DriveCam, Garmin DriveLuxe, Garmin DriveSmart, Garmin DriveTrack
Garmin Drive™ 5 Garmin Drive™ 5LM | Garmin Drive™ 5LM EX | Garmin Drive™ 5LMT GPS navigators Garmin Drive™ 6LM EX GPS navigator Garmin Drive™ 40 GPS navigator Garmin Drive™ 50LM | Garmin Drive™ 50LMT GPS navigators Garmin Drive™ 51 | Garmin Drive™ 51EX | Garmin Drive™ 51LM GPS navigators Garmin Drive™ 52 | Garmin Drive™ 52EX | Garmin Drive™ 52M | Garmin Drive™ 52MT | Garmin Drive™ 52MT-S GPS navigators Garmin Drive™ 60LM | Garmin Drive™ 60LMT GPS navigators Garmin Drive™ 61 | Garmin Drive™ 61EX | Garmin Drive™ 61LMT-S GPS navigators | 32 GB | microSD | Class 2 to 10 |
Garmin Drive™ 53 GPS navigator Garmin Drive™ 53 & Traffic GPS navigator Garmin Drive™ 53 & Live Traffic GPS navigator | 256 GB | microSD | Class 2 to 10 |
Garmin DriveAssist™ 50 | Garmin DriveAssist™ 51 GPS navigators with camera (Map SD card slot) | 32 GB | microSD | Class 2 to 10 |
Garmin DriveAssist™ 50 and Garmin DriveAssist™ 51 GPS navigators with camera (Camera SD card slot) | 64 GB | microSD | Class 10 |
Garmin DriveCam™ 76 GPS navigator with camera (Map SD card slot) | 512 GB | microSD | Class 4 to 10 |
Garmin DriveCam™ 76 GPS navigator with camera (Camera SD card slot) | 512 GB | microSD | Class 10 |
Garmin DriveLuxe™ 50LMTHD GPS navigator Garmin DriveLuxe™ 51 GPS navigator | 32 GB | microSD | Class 2 to 10 |
Garmin DriveSmart™ 5 GPS navigator Garmin DriveSmart™ 6 GPS navigator Garmin DriveSmart™ 7 GPS navigator Garmin DriveSmart™ 50LMTHD GPS navigator Garmin DriveSmart™ 60LMT GPS navigator Garmin DriveSmart™ 70LMT GPS navigator Garmin DriveSmart™ 71 EX GPS navigator Garmin DriveSmart™ 51LMT-S GPS navigator Garmin DriveSmart™ 55 & Traffic GPS navigator Garmin DriveSmart™ 61LMT-S GPS navigator Garmin DriveSmart™ 65 & Traffic GPS navigator | 32 GB | microSD | Class 2 to 10 |
Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator | 32 GB | microSD | Class 2 to 10 |
Garmin DriveSmart 65™ Traveler's Edition GPS navigator | 32 GB | microSD | Class 2 to 10 |
Garmin DriveSmart™ 66MT-S GPS navigator Garmin DriveSmart™ 76 GPS navigator | 256 GB | microSD | Class 2 to 10 |
Garmin DriveSmart™ 66MT-S with Amazon Alexa GPS navigator Garmin DriveSmart™ 76 with Amazon Alexa GPS navigator Garmin DriveSmart™ 86 with Amazon Alexa GPS navigator | 256 GB | microSD | Class 2 to 10 |
Garmin DriveTrack™ 70 GPS navigator Garmin DriveTrack™ 71 GPS navigator | 32 GB | microSD | Class 2 to 10 |
Garmin DriveAssist 50 and Garmin DriveAssist 51
Garmin Drive 53
Garmin Drive 53 & Traffic
Garmin Drive 53 & Live Traffic
Garmin DriveCam 76
Most Other Garmin Automotive Devices
Garmin Speak Plus with Amazon Alexa With Built-in Dash Cam
Garmin Speak™ Plus | 4GB | 64 GB | microSD | Class 10 |
GVN 52 and GVN 53
GVN 52 and GVN 53 | 8 GB | microSD | Class 2 to 10 |
nüLink! LIVE
nüLink!® 1690 LIVE GPS navigator nüLink!® 1695 LIVE GPS navigator nüLink!® 2390 LIVE GPS navigator | 32 GB | microSD | Class 2 to 10 |
nüvi
nüvi® 30 | nüvi® 40 | nüvi® 50 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 42 | nüvi® 44 | nüvi® 52 | nüvi® 54 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 55 | nüvi® 56 | nüvi® 65 | nüvi® 66 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 57 | nüvi® 58 | nüvi® 67 | nüvi® 68 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 200 | nüvi® 250 | nüvi® 260 | nüvi® 270 GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 200W | nüvi® 250W | nüvi® 260W GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 205 | nüvi® 255 | nüvi® 265 | nüvi® 275 GPS navigators | 32 GB | SD/microSD | Class 2 to 10 |
nüvi® 255W | nüvi® 265W | nüvi® 285W GPS navigators | 32 GB | SD/microSD | Class 2 to 10 |
nüvi® 465 GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 500 | nüvi® 550 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 750 | nüvi® 760 | nüvi® 770 | nüvi® 780 GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 755 | nüvi® 765 | nüvi® 775 | nüvi® 785 GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 1100 | nüvi® 1200 | nüvi® 1250 | nüvi® 1260 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 1300 | nüvi® 1350 | nüvi® 1370 | nüvi® 1390 | nüvi® 1450 | nüvi® 1490 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2200 | nüvi® 2250 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2300 | nüvi® 2350 | nüvi® 2360 | nüvi® 2370 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2450 | nüvi® 2460 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2455 | nüvi® 2475 | nüvi® 2495 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2457 | nüvi® 2497 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2557 | nüvi® 2577 | nüvi® 2597 | nüvi® 2598 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2555 | nüvi® 2595 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2539 | nüvi® 2559 | nüvi® 2589 | nüvi® 2599 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2639 | nüvi® 2689 | nüvi® 2699 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 2757 | nüvi® 2797 | nüvi® 2798 | nüvi® 2789 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 3450 | nüvi® 3490 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 3550 | nüvi® 3590 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 3597 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi® 3750 | nüvi® 3760 | nüvi® 3790 GPS navigators | 32 GB | microSD | Class 2 to 10 |
nüvi 295W, nüvi 850, nüvi 880, nüvi 855, and nüvi 885
nüvi® 295W GPS navigator | 8 GB | microSD | Class 2 to 10 |
nüvi® 850 | nüvi® 880 | nüvi® 855 | nüvi® 885 GPS navigators | 8 GB | microSD | Class 2 to 10 |
nüvi 350, nüvi 360, nüvi 370, nüvi 650, nüvi 660, nüvi 670, nüvi 680, and nüvi 5000 GPS Navigators
Devices in the nüvi® 300, 600, and 5000 series can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For more information, see the FAQ .
nüvi® 350 | nüvi® 360 | nüvi® 370 GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 650 | nüvi® 660 | nüvi® 670 | nüvi® 680 GPS navigators | 32 GB | SD | Class 2 to 10 |
nüvi® 5000 GPS navigators | 8 GB | SD | Class 2 to 10 |
nüviCam™ LMTHD
nüviCam™ LMTHD GPS navigator with camera (Camera SD card slot) | 64 GB | microSD | Class 4 to 10 |
nüviCam™ LMTHD GPS navigator with camera (Map SD card slot) | 32 GB | microSD | Class 2 to 10 |
Video Instructions on Where to Insert the microSD card into the nüvi®Cam:
Overlander
64 GB cards and larger will often be labeled SDXC (Extended Capacity). SD, SDHC, and SDXC cards must be formatted as FAT32. See Overlander - Formatting the Memory Card. If you are using a 64 GB card or higher and your computer does not allow you to format it as FAT32, it is recommended to use a 32 GB card instead. See Using a 64 GB microSD/SD Memory Card or Larger.
Overlander® GPS navigator | 256 GB | microSD | Class 10 |
StreetPilot
i-Series devices and the StreetPilot® c300 series do not support the SDHC (High Capacity) cards. All other devices support SDHC cards.
StreetPilot® c340 | StreetPilot® c320 | StreetPilot® c330 | StreetPilot® c340 GPS navigators | 2 GB | SD | Class 2 to 10 |
StreetPilot® c510 | StreetPilot® c530 | StreetPilot® c550 | StreetPilot® c580 GPS navigators | 4 GB | SD | Class 2 to 10 |
StreetPilot®® i2 | StreetPilot® i3 | StreetPilot® i5 GPS navigators | 2 GB | SD | Class 2 to 10 |
StreetPilot® 7200 | StreetPilot® 7500 GPS navigators | 2 GB | SD | Class 2 to 10 |
Tread
Tread® - Base Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® 2 GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® - 2 Overland Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® - 2 SxS Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® - Overland Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® - SxS Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® XL - Baja Chase Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® XL - Baja Race Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Tread® XL - Overland Edition GPS navigator | 256 GB | microSD | Class 2 to 10 |
Click Below for Video Instructions on Where to Insert your Device's SD microSD card:
Tread and Tread - Base Edition GPS Navigators
Tread 2 GPS Navigator
Tread® 2 - Overland Edition GPS Navigator
Tread® 2 - SxS Edition GPS Navigator
Tread - Overland Edition and Tread XL - Overland Edition
Tread - SxS Edition
zūmo
64 GB cards or larger will often be labeled SDXC (Extended Capacity). SD, SDHC, and SDXC cards must be formatted as FAT32. If you are using a 64 GB card or larger and your computer does not allow you to format it as FAT32, it is recommended to use a 32 GB card instead. See Using a 64 GB microSD/SD Memory Card.
zūmo® 220 GPS navigator zūmo® 350 GPS navigator zūmo® 390 GPS navigator zūmo® 590 GPS navigator zūmo® 660 GPS navigator | 32 GB | microSD | Class 2 to 10 |
zūmo 395 | zūmo® 396 GPS navigators zūmo® 595 GPS navigator | 64 GB | microSD | Class 2 to 10 |
zūmo® 450 GPS navigator zūmo® 550 GPS navigator | 4 GB | SD | Class 2 to 10 |
zūmo® 665 GPS navigator | 8 GB | microSD | Class 2 to 10 |
zūmo® XT GPS navigator | 256 GB | microSD | Class 2 to 10 |
zūmo® XT2 GPS navigator | 256 GB | microSD | Class 2 to 10 |
