How to Activate an inReach Subscription
Before you can use the messaging and SOS functions on an inReach® device, you must create an account and activate a service plan by connecting your inReach device with a compatible Garmin app or by visiting the Garmin Explore™ website. If you are having issues logging into your inReach account or creating a new account, see Related at the bottom of the page.
IMPORTANT
  • You cannot add additional users to Consumer Plan inReach accounts. To have multiple users with assigned devices on a single account, you need a Professional account.
  • Activation fees are non-refundable. Read and view the following before starting to set up your account - Difference Between inReach Personal and Professional Plans. Pick the plan that is best for your usage.
  • If you need to activate the device on a professional account, see - or .
  • If your plan is currently suspended and you are needing to reactivate it, see - Reactivating a Suspended inReach Device.
Activating an inReach Subscription With the Garmin Messenger™ App
Most inReach devices can be activated on a subscription by pairing the device with the Garmin Messenger app on a smartphone.
For a list of compatible devices and instructions, see - Pairing Instructions for Garmin Messenger App Compatible inReach Devices.
If you are unable to use the Garmin Messenger app for any reason, refer to the alternative activation steps below to activate a subscription at the Garmin Explore website.
Activating an inReach Subscription With the Earthmate® App
The following inReach devices can be activated using the Earthmate app as long as the app is up to date. For instructions, see - .
  • inReach for Android | inReach for PN-60w | inReach for Smartphones
  • inReach SE® | inReach SE®+
  • inReach Explorer® | inReach Explorer® +
  • inReach Mini
If you are unable to use the Earthmate app for any reason, refer to the alternative activation steps below to activate a subscription at the Garmin Explore™ website.
Activating an inReach Subscription on the Garmin Explore Website
If you are activating a brand new device, proceed with the steps below. If you have an inReach device that was acquired second-hand, it may need to be reset before proceeding with these steps. To reset the device, refer to your Owner's Manual.
Relaterede
