My Approach X10 is in the Wrong Language
If your Approach X10 is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the watch, follow the steps for resetting the device.
Changing the Language
- Press the Device Key to enter the Menu
- Touch
- Swipe up 4 times
- Touch the screen
- Swipe until you see your language
- Touch the screen
You have now changed the language on your Approach X10.
If you were unable to change the language on your watch using the steps above, select the option for factory reset below and follow those steps to reset your watch. You will be prompted to select a language after the reset, during initial setup.
Factory Reset
- Press the Device key to view the menu
- Select
- Swipe down once
- Select Restore Defaults
- Select
For a video on how to perform a Factory Reset, refer to the video below.
NOTE: Any scorecards saved to the watch will remain on the watch after a factory reset.
