Customizing a Chartplotters Startup Image
Some chartplotters1 startup images are able to be customized. To customize the startup the image, follow these steps:
Insert a micro/SD card that contains the image into the chartplotter
Select Settings > System > Sounds and Display > Startup Image > Select Image
Select the micro/SD card slot
Select the image
Select Set as Startup Image
NOTE: The file type for the image can be .jpeg, .png, or .bmp and can be located anywhere on the micro/SD card.
For the best fit for the startup images, use an image that has the following dimensions, in pixels:
1The following GPSMAP series are compatible with this feature: 7x2 / 9x2, 7x2 / 9x2 Plus, 7x3 / 9x3, 1xx2 / 12x2, 12x3, 74xx / 76xx, 84xx / 86xx.
