Can Garmin Watches Broadcast Heart Rate Data?
Many Garmin watches can broadcast heart rate, to verify compatibility and to find steps on how to broadcast refer to your owner's manual.
Many third party apps and devices may require the heart rate to be broadcast over Bluetooth to receive a signal. Any Garmin device or sensor that broadcasts over Bluetooth will also broadcast over ANT+ whenever you enable broadcasting. For devices compatible with Bluetooth broadcasting see the list below.
Watches That Broadcast Heart Rate Data via Bluetooth
  • Approach® S70 - 42mm | Approach® S70 - 47mm
  • D2™ Air
  • D2™ Air X10
  • D2™ Mach 1
  • Descent™ G1 | Descent G1 Solar
  • Descent™ Mk2 | Descent Mk2i | Descent Mk2S
  • Enduro™
  • Enduro™ 2
  • epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition 47 mm
  • epix™ Pro (Gen 2) - Standard Edition 42 mm| epix™ Pro (Gen 2) - Sapphire Edition 42 mm
  • epix™ Pro (Gen 2) - Standard Edition 47 mm| epix™ Pro (Gen 2) - Sapphire Edition 47 mm
  • epix™ Pro (Gen 2) - Standard Edition 51 mm| epix™ Pro (Gen 2) - Sapphire Edition 51 mm
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • Forerunner® 55
  • Forerunner® 245 | Forerunner® 245 Music
  • Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • quatix® 6 | quatix® 6X Solar | quatix® 6 Titanium
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu® 2 | Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq 2 Music
  • vivosmart® 5
Garmin Heart Rate Straps That Broadcast Data via Bluetooth
In addition to the above watches, the following heart rate monitor straps can also broadcast their signal via Bluetooth which is a common feature needed to transmit this data to third-party apps.
  • HRM-Dual™ heart rate monitor
  • HRM-Pro™ heart rate monitor
  • HRM-Pro™ Plus heart rate monitor
For more information on compatibility and pairing with third-party apps, we recommend visiting the app's help pages or contacting the developer of the app.
