SD Memory Card Compatibility for the Garmin Dash Cam 54 and Garmin Dash Cam 55
Garmin Dash Cams require an SD card to record video or take pictures due to the device does not have any internal memory for storing files.
NOTE: The Garmin Dash Cam 54 does not come with a microSD card.
SD Card specifications for Garmin Dash Cam 54 and 55:
Minimum Capacity | Maximum Capacity | Card Types | Speed Class |
4 GB | 64 GB | microSD, microSDHC, microSDXC | Class 10 (or higher) is required |
SD/microSD cards can be purchased from Garmin or other retailers.
SD memory cards wear out after they are overwritten a large number of times.
- Your device detects memory card errors automatically and alerts you when it is time to format or replace your memory card
To help extend the useful life of your SD card, Garmin recommends the following:
Back up saved footage and format the memory card at least once every 6 months
Transferring saved footage, see your device's Owner's Manual.
Formatting a microSD Card on a Garmin Dash Cam 45, 54, 55, or 65W
Replace the memory card periodically due to the dash camera recording continuously
Turn off the device when your vehicle is not in use to prevent the dash camera from recording unneeded footage
Use a memory card with a higher storage capacity
Higher-capacity memory cards are overwritten less frequently and will usually last longer
Use a high-quality memory card with a speed rating of class 10 or higher
Purchase your replacement memory card from a high-quality manufacturer and a reputable vendor
The following SD cards have been tested and verified to work with the Garmin Dash Cam 54 and Garmin Dash Cam 55 devices.
SD cards not listed may or may not work with your device.
Class 10 is required.
Brand | Specs | Size |
ADATA | UHS-I | 16 and 32 GB |
Kingston | EVERPRO UHS-I U1 | 32 and 64 GB |
Samsung | Pro+ XC | 64 GB |
SanDisk | Class 10 | 4, 8, 16, and 32 GB "Extreme HC" |
Transcend | High Endurance | 4, 8, 16, and 32 GB |
Toshiba | Exceria UHS-I | 16 and 32 GB |
