Marine Network Sharing Compatibility
Below is a breakdown of Garmin marine device ability to share and receive information across the Garmin Marine Network. The devices listed will only share with other devices within the same table. For example, an echoMAP Plus device cannot share any data with a GPSMAP device.
IMPORTANT NOTES:
- The echoMAP 70s/70dv will not share sonar with a GPSMAP 8000 series device and a GPSMAP 8000 series device will not share sonar with the echoMap 70s/70dv.
- It is only possible to share preloaded charts with a device that doesn't have preloaded charts.
echoMAP Series
Device | Built-In Sonar | Preloaded Charts | Supplemental Charts | User Data | Quickdraw Contours |
echoMAP Plus 7x/9x | ✔ | ✔ | ✔ | ✔ | ✔ |
echoMAP Ultra Series | ✔ | ✔ | ✔ | ✔ | ✔ |
echoMAP UHD Series | ✔ | ✔ | ✔ | ✔ | ✔ |
GPSMAP 3000 Series
Device | Preloaded Charts | Supplemental Charts | User Data |
GPSMAP 3000 | ✔ | ✔ | ✔1 |
1User Data transferred over the network must be manually initiated
Grey/Silver GPSMAP 4000/5000/6000/7000 Series
GPSMAP 40xx/42xx | ✔ | ✔ | ✔1 |
GPSMAP 50xx/52xx | ✔ | ✔ | ✔1 |
GPSMAP 60xx/62xx | ✔ | ✔ | ✔1 |
GPSMAP 70xx/72xx | ✔ | ✔ | ✔1 |
Black GPSMAP 500/700/900/1000/1200/7000/8000 Series and Legacy echoMAP 70s/dv
echoMAP 70s/70dv | ✔ | X | X | ✔2 | ✔ |
GPSMAP 5x7 | ✔ | X | X | ✔2 | ✔ |
GPSMAP 7x1/8x0/10x0 | ✔ | ✔ | ✔ | ✔2 | ✔ |
GPSMAP 7x2/9x2/10x2/12x2 | ✔ | ✔ | ✔ | ✔ | ✔ |
GPSMAP 74xx/76xx | ✔ | ✔ | ✔ | ✔ | ✔ |
GPSMAP 80xx/82xx/85xx | ✔ | ✔ | ✔ | ✔ | ✔ |
GPSMAP 84xx/86xx/87xx | ✔ | ✔ | ✔ | ✔ | ✔ |
2User data sharing is only compatible between other devices marked with "✔2"
Video sharing:
The following GPSMap devices have built-in video encoders which allow video to be shared across the Garmin Marine Network:
- GPSMap 84xx/86xx(xsv)
- GPSMap 7x2
- GPSMap 9x2
- GPSMap 10x2
- GPSMap 12x2
The following chartplotters accept video over the Garmin Marine Network:
- GPSMap 74xx/76xx(xsv)
- GPSMap 7x2
- GPSMap 9x2
- GPSMap 10x2
- GPSMap 12x2
- GPSMap A12
- Yamaha CL7
