Adding and Using the Altitude Acclimation Widget
The Altitude Acclimation widget will give you at-a-glance information on your current elevation and how you are acclimating to the altitude. When opening the widget you will see more information about how you are acclimating, including weekly averages for Pulse Ox,1 respiration rate, and resting heart rate.
If the widget is displaying Inactive, it means that you are not at a high enough elevation for the widget to display altitude acclimation information.
D2 Mach 1, epix (Gen 2) Series, fenix 7 Series, Forerunner 955/955 Solar Instinct 2 Series, tactix 7 Series
Hold UP/MENU to enter the main menu.
Select Appearance.
Select Glances.
Select +Add.
Select Alt. Acclimation.
The Altitude Acclimation widget is now in your widget loop.
Select an option below to see an example and learn about the items you will see in the widget.
Widget at a Glance
The number represents your current altitude acclimation.
The arrow to the right of your current altitude acclimation indicates how you are trending from the previous day.
Full Widget View
The number at the top of the widget is the altitude you are currently acclimated to. The arrow next to it indicates how your acclimation is trending from the previous day.
Current Elevation indicates your current altitude.
The line with dots on the graph shows your daily acclimation average.
The gray graph shows elevation over the week.
The numbers to the left and right of the graph are elevation.
The letters at the bottom of the graph represent days of the week.
Average Pulse Ox
The line with colored dots represents your daily average Pulse Ox.
The numbers to the left of the graph are elevation.
The numbers to the right of the graph are Pulse Ox percentage.
Average Respiration Rate
The line with dots represents your daily average Breaths Per Minute (BRPM).
The numbers to the right of the graph are BRPM.
Average Resting Heart Rate
The line with dots represents your daily average Resting Heart Rate (RHR).
The numbers to the right of the graph are RHR levels.
1 Pulse Ox will only display if All-Day Pulse Ox is enabled for your watch. Enabling All-Day Pulse Ox will use additional battery power.
