"No Matches found" or "Cannot Find Search Results" When Searching for an Address or Point of Interest
If the error message “No matches found” or "Cannot find search results" is displayed when searching for an address or location it may be due to:
    • The maps on the device are not enabled
    • The device is not set to search near the specified location
    • The maps on the device do not contain the region being searched
    • The device is not understanding an address abbreviation or there was a typo
See below for more information to fix these common issues with searching locations.
To verify the maps on the device are enabled:
  1. Touch Tools
  2. Touch Settings
  3. Touch Map
  4. Touch Info
  5. On the Info page, make sure there is a check mark in the box to the left of the mapping version. If there is not a check mark, touch the empty box to place a check mark and enable the map.
  6. Verify the region 1 listed includes the area needed
Ensure the device is set to search near the specific location:
For more details on searching click here for help with searching for a destination.
Ensure the maps on the device contain the area being searched:
If the issue was first noticed after completing a map update, it may indicate that a smaller map region was installed during the last map update. To change the installed region, or install the full map to an SD card (recommended) see: Reinstall or change map coverage using Garmin Express
Ensure that the data being entered is correctly formatted and there are no typo's:
The device may have trouble finding an address if there is a typo. It is recommended to double check spelling if the address can't be found. Searching for a street using abbreviations is generally fine (e.g. 123 Main St NE). However, since addresses are sometimes abbreviated different ways, it is often easier to leave the abbreviation out (e.g. 123 Main). This will generally yield a list of results where the correct address can be selected from the list. The device will be searching for the address as it is typed and may provide suggestions.
1To see detailed descriptions of Garmin North American map regions visit: States, Provinces, and other areas included in the regions listed during a North America map update. If the region loaded on the device doesn't include what is needed, visit: Reinstall or change map coverage using Garmin Express to change the region.
Relaterede
