Venu Display Brightness Settings
Display brightness levels for the Venu® | Venu® 2 | Venu® 2S | Venu® 2 Plus | Venu® Sq | Venu® Sq - Music Edition | Venu® Sq 2 | Venu Sq® 2 - Music Edition | Venu® 3 | Venu® 3S watches have multiple options to choose from. To access the brightness menu follow the steps below.
  1. From watch face on your display press and hold the bottom button.
  2. Select the Gear icon or Settings.
  3. Select System.
  4. Select Display.
  5. Select Brightness.
Auto Brightness Options
To turn on auto-brightness select auto brightness icon until you see the three sun options beside it. Once you have this selected you will have three options for the brightness level.
Low:
Screenshot showing Venu brightness set to low setting
Medium:
Screenshot showing Venu brightness set to medium setting
High:
Screenshot showing Venu brightness set to high setting
After selecting a brightness level it will automatically adjust based on the ambient light sensor to keep the device within the brightness setting you choose to make it easier to see in different lighting conditions.
Manual Brightness Options
If you would like to set the brightness level manually, select Venu Auto Brightness until you see only two sun options beside it. It should appear like the image below.
Screenshot showing Venu brightness set to manual setting
Once this is showing, you can select the bottom sun to lower the brightness, or the upper sun to raise it. It will adjust by 10% increments between 10% and 100% brightness.
