Managing Maps on the GPSMAP 67 Series With Garmin Express
The Manage Maps feature allows you to install additional TopoActive map regions on the GPSMAP® 67 and GPSMAP® 67i outdoor handhelds. It also allows you to view, update, remove, or add maps.
For syncing inReach® account changes and user data (waypoints, routes, tracks, and activities), see Related for pairing and syncing with the Garmin Explore™ app.
Important Notes
  • Data stored on the device (waypoints, routes, tracks, and activities) is kept in a separate reserved part of the device memory so it does not impact the free space.
  • You can install a microSD® memory card, up to 32 GB, in the handheld device for additional storage.
  • At this time, there are no plans to provide the Manage Maps feature to older devices.
  • Garmin Express is not compatible with mobile devices, like smartphones or tablets. If you are looking for help to troubleshoot Garmin Express issues, visit the Garmin Express Support Page.
Managing Maps With Garmin Express™ Software
If this is your first time using a computer with your handheld, you will need to download and install the Garmin Express program. For information on downloading and installing Garmin Express, see - How Do I Install Garmin Express?.
  1. Connect your handheld to your computer with the USB cable.
  2. Launch Garmin Express.
  3. Select your handheld.
  4. Garmin Express will then display available updates. If it says you are up to date, then the software and maps currently installed to your handheld are on the most current version(s).
    • Install or Install All installs updates to software and any maps that are currently installed to your handheld.
    • View Details shows details on the specific updates (software, GPS, or map).
    • Map Details shows what maps are currently installed to your handheld. If you click on it and then Options, this will allow you to reinstall any maps that are already up to date.
      Install All Button for Updates Available in Garmin Express
Opening the Manage Maps Page
After selecting your device in Garmin Express, click on the Manage Maps button to open the Manage Maps page.
Red arrow point to Manage Maps Button
Using the Manage Maps Page
Manage Maps Option in Garmin Express
Options you may see within this window:
My Maps vs. Removable Storage
  • My Maps - Choose which maps are installed to the handheld's internal storage.
  • Removable Storage - Choose which maps are installed to a microSD card in the handheld.
Map Types
  • TopoActive - TopoActive mapping
Functions
  • View – Shows that map region's coverage
  • Change Region – Drop-down allows you to select a smaller region for preloaded City Navigator or TopoActive maps if smaller regions are available; only one region can be installed
    Example
    Select a Region Example in Garmin Express
  • Update to Latest Version – When a new version is detected, you can install the update. If unable to update a map in Removable Storage, you may need to remove the map, then add it again to install the latest map version.
  • Checkbox - If unchecked, this removes the map from the handheld. If checked, this adds the map to the handheld. If the box is grayed out, there is not currently enough space available to add the map.
  • Chart - Allows you to see your current handheld storage (free space and amount taken by maps or other critical software). If you hover over a map option, or uncheck/check it, the impact to the storage space is displayed.
    Device Storage Chart in Garmin Express
    • If you hover over a map option, or uncheck/check it, the impact to the storage space is displayed
After making any changes, including changing regions, you must click Apply Changes in Garmin Express. Garmin Express will then display the progress:
Applying Changes Message in Garmin Express
Adding or Removing Maps
Preloaded maps can be installed to the internal storage of the device (My Maps), or to a microSD card (Removable Storage) as a way to free up space on the device. If you do not need some of the preloaded maps, you can remove them with the ability to add them back at any time.
NOTE: Map selections that are currently installed cannot be moved from My Maps to Removable Storage or vice versa without first removing the map from its current location.
Adding Maps
  1. Open Garmin Express.
  2. Connect the handheld to the computer with the appropriate USB cable.
  3. Select Manage Maps.
  4. Select My Maps, or Removable Storage (recommended).
    • My Maps - Add maps to the internal storage of the device. Keep in mind that the latest version TopoActive maps will not fit in their entirety and you will need to choose a smaller region of the map.
    • Removable Storage - Add maps to a microSD card in the device. This option must be used if you wish to install full coverage for all available maps.
  5. Select a map type.
    map type options
  6. Check the box next to the the map(s) you want added.
    NOTE: For TopoActive maps, select Change Region to choose a smaller region if needed.
    Installing Maps
  7. Select Apply Changes.
  8. Select Continue.
    apply update
  9. The maps will now be added.
Removing Maps
  4. Select My Maps or Removable Storage.
    • My Maps - Remove maps from the internal storage of the device.
    • Removable Storage - Remove maps from a microSD card in the device.
    removing map
  6. Select the box to remove the check mark associated with the map(s) you want removed.
    removing check mark
  8. Select Continue.
    Blue Continue Button
  9. The maps will now be removed.
Troubleshooting Preloaded Mapping Issues
If the preloaded mapping has been moved to Removable Storage it cannot be updated. To update the mapping you will need to remove it from Removable Storage using Manage Maps, then add the mapping back which will install the newest version. See above for steps on how to add and remove mapping.
Relaterede
