D2™ Bravo
D2™ Charlie
D2™ Delta | D2™ Delta PX | D2™ Delta S
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
Descent™ Mk1
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 - 43 mm | Descent™ Mk3i - 43 mm | Descent™ Mk3i - 51 mm
Enduro™
Enduro™ 2
Enduro™ 3
epix®
epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition 42 mm| epix™ Pro (Gen 2) - Sapphire Edition 42 mm
epix™ Pro (Gen 2) - Standard Edition 47 mm| epix™ Pro (Gen 2) - Sapphire Edition 47 mm
epix™ Pro (Gen 2) - Standard Edition 51 mm| epix™ Pro (Gen 2) - Sapphire Edition 51 mm
fēnix® 3 | fēnix® 3 HR | fēnix® 3 Sapphire
fēnix® 5S | fēnix® 5 | fēnix® 5X
fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® E
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 570
Forerunner® 745
Forerunner® 935
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Forerunner® 970
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition | Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition
Instinct® - Standard Edition | Instinct® - Tactical Edition | Instinct® - Esports Edition
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 3
quatix® 5 | quatix® 5 Sapphire
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Bravo
tactix® Charlie
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Venu® X1
Unwetterwarnung bei Garmin-Uhren
Einige Garmin-Uhren sind in der Lage, Unwetterwarnungen anzuzeigen, so dass Sie über Bedingungen informiert werden können, die auf ein herannahendes Unwetter hinweisen könnten. Bevor Sie eine Unwetterwarnung einrichten, sollten Sie die Einheiten zur Messung des atmosphärischen Drucks kennen und wissen, wie sich der atmosphärische Druck während eines Wettersystems verändert.
Wie funktionieren Unwetterwarnungen?
Unwetterwarnungen basieren auf Änderungen des barometrischen Luftdrucks. Die Uhr verwendet einen barometrischen Höhenmesser, um diese Änderungen zu messen und wenn schnelle Änderungen des Drucks erkannt werden, erscheint eine Unwetterwarnmeldung auf der Uhr. Es gibt verschiedene Einheiten für die Darstellung des atmosphärischen Drucks, und Sie können die Einheiten für die Messung des Drucks in eines der folgenden vier unterstützten Formate ändern:
Einheiten des atmosphärischen Drucks
Zentimeter (Hg)
mmHg
Millibar
Hektopascal
Eine Unwetterwarnung wird auf der Grundlage der Geschwindigkeit der Luftdruckänderung über die von Ihnen eingestellte Zeitspanne ausgelöst.
Einstellungen zur Unwetterwarnung
Unwetterwarnungen können aktiviert oder deaktiviert werden. Sie können auch die Rate der Luftdruckänderung anpassen, die eine Unwetterwarnung auslöst. Die Schritte zum Anpassen dieser Einstellungen können je nach Uhrenmodell variieren. Eine Anleitung Sie unter "Einrichten von Alarmen" und "Barometereinstellungen" in Ihrem Benutzerhandbuch.
Fehlerbehebung bei Problemen mit Unwetterwarnungen
Wenn Sie zu wenige oder zu viele Unwetterwarnungen erhalten, versuchen Sie zunächst, die Rate der Luftdruckänderung, die eine Unwetterwarnung auslöst, anzupassen und mit Garmin Express die Software Ihrer Uhr zu aktualisieren. Wenn dies nicht hilft, kann dies an anderen äußeren Faktoren liegen oder daran, dass die Sensoröffnung gereinigt werden muss.
