D2 Mach 1 | D2 Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
Descent™ G2
Descent™ Mk1
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 | Descent™ Mk3i
Enduro™
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 5S | fēnix® 5 | fēnix® 5X
fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix Chronos
fēnix® E
Forerunner® 55
Forerunner® 165 | Forerunner® 165 Music
Forerunner® 245 | Forerunner® 245 Music
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 570
Forerunner® 645 | Forerunner® 645 Music
Forerunner® 735XT
Forerunner® 745
Forerunner® 935
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Forerunner® 970
Garmin Swim™ 2
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® 3 - AMOLED | Instinct® 3 - Solar
Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
Instinct® E
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Charlie
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Venu® X1
Garmin Connect: Persönliche Rekorde (Bestzeiten) für Schwimmbad-Aktivitäten
Garmin Connect hat die Möglichkeit, persönliche Rekorde (im Folgenden mit „PR“ abgekürzt) für Schwimmbad-Aktivitäten von Uhren anzuzeigen, die Schwimmbad-PRs unterstützen. Diese PRs werden für die schnellste Zeit über eine bestimmte Distanz angezeigt.
Garmin Connect kann Schwimm-PRs für folgende Distanzen anzeigen:
100 Meter
100 Yards
400 Meter
500 Yards
750 Meter
1000 Meter
1000 Yards
1500 Meter
1650 Yards
Längste Strecke
Wie funktioniert diese Funktion bei Uhren, die Schwimm-PRs aufzeichnen?
Schwimm-PRs müssen in einer zusammenhängenden Einheit/Intervall ohne Pausen ermittelt werden.
Der 400-Meter-PR kann nicht durch 4 x 100-Meter-Intervalle mit dazwischen liegenden Ruhepausen/Erholungsintervallen erreicht werden.
Der „Längste Strecke“ PR ist eine Ausnahme, da dieser PR für die gesamte Schwimm-Aktivität ermittelt wird. Das bedeutet, dass es während des „Längste Strecke“ PR Ruhepausen/Erholungsintervalle geben kann. Wenn es allerdings Ruhepausen gibt, wird die Zeit des PR diese Ruhepausen mit beinhalten.
Schwimm-PRs können entweder in Yards oder Metern aufgezeichnet werden.
- Eine einzelne Aktivität kann nicht sowohl für einen PR in Yards als auch in Metern zählen. Es gibt nur einen „Längste Distanz“ PR, der in der Maßeinheit der Schwimmbadgröße (Bahnlänge) für das längste Gesamtschwimmen angezeigt wird.
Schwimmbad-PRs können nur durch das Schwimmen der exakten PR-Distanz ermittelt werden.
- Die Aktivität muss in einem Pool durchgeführt werden muss, der die exakten PR-Distanzen ermöglicht. Zum Beispiel kann ein 100 Meter PR nicht in einem 17 Meter Pool ermittelt werden, da 100 nicht ein Vielfaches von 17 ist.
Schwimm-PRs können nur im Schwimmbad-Aktivitätsprofil ermittelt werden.
- PRs werden nicht für Schwimmaktivitäten im Freien ermittelt.
Wie funktioniert diese Funktion bei Uhren, die keine Schwimm-PRs aufzeichnen?
Bei Uhren, die Schwimmbad-Aktivitäten, aber keine Schwimm-PRs, unterstützen, ist es möglich, die PRs manuell in Garmin Connect zuzuweisen. Weitere Informationen zum manuellen Zuweisen von PRs in Garmin Connect finden Sie im verbundenen Artikel unten.
