My Bluetooth Audio is Interrupted by Short Breaks
Bluetooth performs best with line-of-sight operation. Ensure the music device is not covered or obstructed and is located near the Bluetooth module. To prevent interruption to audio streaming over Bluetooth it is recommended that the 'Discoverable' feature is turned off after pairing your device to the FUSION stereo.
While displaying the 'Bluetooth Setting's screen, your smartphone will be searching for Bluetooth devices. This process may cause interruption to Bluetooth audio streaming. It is recommended you exit the 'Bluetooth Settings' screen when not in use.
The below video will explain all you need to know about FUSION's Bluetooth modules.
