Approach® S50
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
Descent™ G2
Descent™ Mk1
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 | Descent™ Mk3i
Edge® 130 Plus
Edge® 530
Edge® 540
Edge® 830
Edge® 840
Edge® 1030 | Edge® 1030 Plus
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
Edge® Explore 2
Enduro™
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® E
Forerunner® 45 | Forerunner® 45 Plus
Forerunner® 55
Forerunner® 165 | Forerunner® 165 Music
Forerunner® 245 | Forerunner® 245 Music
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 745
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Instinct® - Standard Edition | Instinct® - Tactical Edition | Instinct® - Esports Edition
Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition | Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® 3 - AMOLED | Instinct® 3 - Solar
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
Instinct® E
Lily® 2 Active
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Venu® | Venu® 2 | Venu® 2S
Venu® 2 Plus
Venu® Sq | Venu® Sq - Music Edition
Venu® Sq 2 | Venu® Sq 2 - Music Edition
Venu® 3 | Venu® 3S
vívoactive® 3 | vívoactive® 3 Music
vívoactive® 4 | vívoactive® 4S
vívoactive® 5
Garmin Connect App LiveTrack-Funktion
HINWEIS: LiveTrack Unfall-Benachrichtigung sollte NICHT als primäre Methode zur Anforderung von Notfallhilfe verwendet werden. Einzelheiten zu zusätzlichen Funktionen, die Hilfe leisten, finden Sie unter: Einrichten der Notfallhilfe auf einem Garmin-Gerät. Weitere Informationen zur Unfall-Benachrichtigung finden Sie unter: Einrichten der Unfall-Benachrichtigung auf einem Garmin-Gerät.
LiveTrack erstellt eine Echtzeitanzeige Ihres Standorts während einer Aktivität, so dass Freunde und Familie dies mitverfolgen können. Im Folgenden finden Sie eine Liste der am häufigsten gestellten Fragen.
Welche Informationen können geteilt werden?
Die folgenden Informationen können innerhalb einer LiveTrack-Sitzung angezeigt werden, die für eine bestimmte Person freigegeben ist:
HINWEIS: Daten, die mit einem * gekennzeichnet sind, werden angezeigt, wenn Sie unten auf der LiveTrack-Karte die Option Diagramme auswählen.
Aktueller Standort
Durchschnittliches Tempo/Pace
Runden (Auto-Runde oder durch Lap-Taste)
Verstrichene Zeit der Aktivität
Zurückgelegte Distanz
Höhengewinn
Eine geplante Route
Aktuelles Tempo*
Geschwindigkeit*
Aktuelle Höhe*
Herzfrequenz*
Trittfrequenz*
Was sind die Voraussetzungen für die Nutzung von LiveTrack?
Sie benötigen ein LiveTrack-kompatibles Garmin-Gerät. Um sicherzustellen, dass Ihr Gerät mit dieser Funktion kompatibel ist, lesen Sie im Benutzerhandbuch nach und suchen Sie nach „LiveTrack“.
Das Garmin-Gerät muss gekoppelt und mit der Garmin Connect App auf dem Telefon verbunden sein, um LiveTrack verwenden zu können.
Auf iOS-Telefonen muss die App geöffnet sein oder im Hintergrund laufen. Für weitere Details siehe: ( Garmin Connect App: Schließen der iOS-App kann einige Funktionen deaktivieren)
Das gekoppelte Telefon muss während der LiveTrack-Aktivität bei Ihnen sein.
Das Telefon muss ein gutes Mobilfunksignal haben, wenn Sie LiveTrack verwenden. Ein schlechtes Empfangssignal kann die Leistung der Funktion beeinträchtigen.
LiveTrack muss vor der ersten Verwendung in der Garmin Connect App eingerichtet werden.
Deaktivieren Sie VPN, falls ein solches verwendet wird. Die Verwendung eines VPN-Dienstes beeinträchtigt die Standortleistung.
Wie richte ich LiveTrack ein?
Die folgenden Schritte richten LiveTrack für eine aufgezeichnete GPS-Aktivität ein:
HINWEIS: Die folgenden Schritte setzen voraus, dass Sie zuvor ein LiveTrack-kompatibles Gerät mit der Garmin Connect App gekoppelt haben.
Öffnen Sie die Garmin Connect App auf Ihrem Smartphone.
Wählen Sie Mehr (unten rechts), um das Menü aufzurufen.
Wählen Sie Sicherheit und Tracking.
Wählen Sie LiveTrack.
Wenn Sie dazu aufgefordert werden, wählen Sie Ich stimme zu. Von hier aus werden die von LiveTrack unterstützten Geräte aufgelistet.
Wählen Sie
(oben rechts).
Wählen Sie Einstellungen.
Richten Sie jede LiveTrack Einstellung ein. Wählen Sie Hilfe in der oberen rechten Ecke um mehr über die Einstellungen zu erfahren:
E-Mail: Fügen Sie Empfänger hinzu, die per E-Mail einen Link zu Ihrem Standort erhalten, sobald Sie LiveTrack starten.
Sie können einen Link zu Ihrem Standort per Textnachricht oder andere Nachrichten-Apps weitergeben, indem Sie
(Android) oder
(iOS) auf dem Bildschirm "Unterstützte Geräte" auswählen, sobald eine LiveTrack-Sitzung läuft.
GroupTrack: Teilen Sie Ihren Standort mit Verbindungen auf deren kartenfähigen Garmin-Geräten mit.
Strava Beacon: für Garmin: Strava Beacon aktivieren, wenn eine LiveTrack-Sitzung beginnt.
Twitter: Erlauben Sie Garmin Connect, einen Tweet über Ihr Twitter-Konto zu senden, wenn Sie LiveTrack starten.
LiveTrack verlängern: Lassen Sie Ihre LiveTrack-Sitzung noch 24 Stunden nach Ende der Sitzung sichtbar.
Wählen Sie den Pfeil in der linken oberen Ecke, um das Menü Einstellungen zu verlassen.
Wie starte ich eine LiveTrack-Sitzung?
Eine LiveTrack-Sitzung kann entweder manuell oder, falls kompatibel, über die Option "Automatisch Starten" gestartet werden. "Automatisch Starten " kann über den Bildschirm "Unterstützte Geräte" von LiveTrack umgeschaltet werden. Wenn diese Einstellung nicht vorhanden ist, ist Ihr Gerät nicht mit "Automatisch Starten" kompatibel.
Was ist die Funktion "Automatisch starten"?
Einige Modelle verfügen über eine Auto-Start-Einstellung, mit der LiveTrack immer dann gestartet wird, wenn eine kompatible Outdoor-Aktivität auf der Uhr gestartet wird. Diese Einstellung kann mit den folgenden Schritten in der Garmin Connect™-App aktiviert werden:
- Schalten Sie Automatisch Starten
ein.
Was ist die Funktion "Strecke anzeigen"?
Informationen zu der LiveTrack-Funktion "Strecke anzeigen" finden Sie im folgenden Artikel: Was ist bei LiveTrack die Funktion Strecke anzeigen in der Garmin Connect App?
Was ist die Funktion "Nachrichtenversand für Zuschauer"?
Zuschauer-Nachrichten sind eine Funktion, mit der Ihre LiveTrack-Follower Ihnen während Ihrer Laufaktivität Audio- und Textnachrichten senden können. Sie können diese Funktion in den LiveTrack-Einstellungen der Garmin Connect™-App einrichten. Um Audiomitteilungen zu empfangen, müssen Sie Bluetooth-Kopfhörer mit der Uhr verbinden. Weitere Informationen finden Sie unter Was ist die Funktion "Nachrichtenversand für Zuschauer" auf meiner Uhr?
HINWEIS: Ihr gekoppeltes Telefon muss mit einem Datentarif ausgestattet sein und sich in einem Gebiet mit Netzabdeckung befinden, in dem Daten verfügbar sind.
Was ist die Funktion "Live-Eventfreigabe"?
Live-Eventfreigabe ist nur für Android und bestimmte Garmin-Geräte verfügbar. Details zur Funktion "Live Eventfreigabe" finden Sie unter: Garmin Live Eventfreigabe
Warum zeigt LiveTrack einen anderen durchschnittlichen Geschwindigkeitswert an als eine Aktivität in Connect?
Die Seite LiveTrack zeigt die Durchschnittsgeschwindigkeit ab dem Zeitpunkt an, an dem die Aktivität gestartet wurde, und berücksichtigt nicht, wenn das Gerät gestoppt wird, wie z.B. an Ampeln oder Pausen.
Wie kann ich die LiveTrack-Funktion deaktivieren?
Öffnen Sie die Garmin Connect App.
Wählen Sie Mehr (unten rechts).
Wählen Sie Sicherheit und Tracking oder LiveTrack.
Wählen Sie
(oben rechts).
Wählen Sie LiveTrack-Daten und Datenschutz.
Wählen Sie Abmelden.
Hilfreiche LiveTrack-Tipps
Im Folgenden finden Sie Tipps zur Verbesserung der LiveTrack-Erfahrung sowohl für Sie als auch für diejenigen, mit denen Sie Ihre Aktivitätsverfolgung teilen:
Bevor Sie eine Aktivität auf Ihrem Gerät starten, stellen Sie sicher, dass Sie ein gutes GPS-Signal haben. Warten Sie nach der Erfassung eines Signals einige Augenblicke, bevor Sie mit dem Training beginnen. Dies ermöglicht es der LiveTrack-Karte, Ihren Standort zu Beginn einer Aktivität anzuzeigen.
Sie müssen bei Garmin-Uhren sicherstellen, dass Sie das LiveTrack-Symbol
auf Ihrer Uhr sehen, das eine aktive Sitzung anzeigt.
Der Verlust eines Mobilfunksignals kann dazu führen, dass die LiveTrack-Karte Ihren aktuellen Standort nicht anzeigt. LiveTrack zeigt Ihren letzten bekannten Standort an und sollte wieder aufgenommen werden, sobald Ihr Telefon wieder ein Signal gefunden hat.
Verwenden Sie bei kompatiblen Geräten die Autostart-Funktion in LiveTrack. Dadurch kann Ihre Aktivität automatisch bei jedem Start einer Aktivität freigegeben werden.
Wenn Sie mehr als ein Garmin-Gerät mit der Garmin Connect App gekoppelt haben, stellen Sie sicher, dass Sie unter Geräte in den LiveTrack-Einstellungen das richtige Gerät auswählen, bevor Sie mit Ihrer Aktivität beginnen.
Wenn Sie mit Ihrem kompatiblen LTE-Gerät keine Audio- oder Textnachrichten von Ihren LiveTrack-Followern erhalten, siehe: Was ist die Funktion "Nachrichtenversand für Zuschauer" auf meiner Uhr?
