How to Show a Location Different Than the Current Location on a Colorado
If you would like the Colorado® outdoor handheld to show a different location other than your current location, you will need to set the device into Demonstration mode. At that point, you can change the location. If the device is in Normal mode, it will automatically locate its correct position.
To change the current location:
- Select Shortcuts to access Main menu
- Select Setup
- Select System
- Select GPS
- Select Demo Mode
- Return to Main Menu
- Select Others
- Select Satellite
- Press Options soft-key
- Select Set Location On Map
- Use the Map to select the desired position
- Select Back button
You have now selected the desired location to be used as your current location on the Colorado handheld.
To quickly have your device locate your current location, turn the device off and back on. You can also follow steps 1 though 4 from above, and select Normal mode to locate your current location.
