- Open File Explorer
- Click the Organize button under the left side of your menu bar
- Click Folder and Search Options
- Click the View tab
- Under Advanced settings, click Show hidden files and folders, and then click OK
How to View the Internal Serial Number on Your Plotter Card
Sometimes, you may be asked to provide the internal serial number file (nTag.txt) from your Navionics® card for troubleshooting or technical support. This situation may arise if you only have the microSD card and have misplaced the SD sleeve. In order to do this you will need to set your computer to Show Hidden Files. Insert the card into your PC, and follow the steps below depending on the operating system of your computer.
- Open the File Explorer
- Under the Show/Hide section, select the check box by Hidden Items
Use the shortcut key ( SHIFT + CMD + . ) while the contents of the card are open
