Verifying Maps Installed on an Automotive Device
NOTES:
- In accordance with the Lifetime Maps and Maps Terms and Conditions, map updates and/or Downloadable Content (DLC) are no longer available to download or purchase and cannot be activated and/or associated with the Garmin devices listed in Map Updates and Downloadable Content No Longer Available to Download or Purchase.
- This is due to these devices not having sufficient memory capacity and other required technical capabilities to utilize current map data.
To Check the Map Version Loaded On Your Device:
1. Touch Tools
2. Touch Settings
3. Touch Map
4. Touch Info
5. Within this section, you will see all of the mapping loaded onto the device.
If there is no checkmark next to the map(s) listed, touch the box to add a check. This will enable the mapping on the device.
If the Map Info screen is inaccessible or blank, see Restoring Maps Missing or Deleted Off an Automotive Device.
Current Map Version: 2026.20 (North America) as of June 25, 2025.
See North America Map Coverage for more information about coverage offered with North America mapping.
