My Rino 750 or 755t is in the Wrong Language
If your Rino® 750 or 755t outdoor handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
Steps will vary slightly depending on which display mode the handheld is set to.
Classic Mode (Default)
  1. If necessary, tap Back Arrow until you reach the home screen:
    Classic Mode
  2. Swipe up from the bottom of the screen to open the application drawer.
  3. Tap Wrench and Screwdriver.
  4. Tap Gear Wheel.
  5. Tap the second item in the menu.
  6. Tap the desired language.
Activity Mode
    Activity Mode
  2. Tap Three Bar Menu Symbol.
  3. Tap Gear Wheel.
  4. Tap the second item in the menu.
  5. Tap the desired language.
Related
