Showing or Hiding Tracks on the Map of the eTrex 10/20/20x/22x/30/30x/32x
On the eTrex® 10, 20, 20x, 22x, 30, 30x, and 32x outdoor handhelds you can choose to show certain saved tracks on the map and hide other tracks from the map.
Showing or Hiding Saved Tracks on the Map
  1. From the main menu, select Track Manager.
  2. Select a saved track.
    • Additional steps for archived tracks:
      1. Select Archived Tracks.
      2. Select the track you want to change.
      3. Select Make Favorite.
      4. Select the saved track.
  3. Select Show on Map or Hide on Map to toggle the track visibility.
Showing or Hiding the Current Track on the Map
  1. From the main menu, select Setup.
  2. Select Tracks.
  3. Select Track Log.
  4. Select Record, Do Not Show or Record, Show on Map to toggle visibility of the current track.
