Viewing Hunting Management Units for the Rino 650, 650t and 655t
Hunting Management Units (HMU) will not be turned on by default when the HuntViewPlus is installed on the Garmin. Instructions for enabling the mapping are below as well as some helpful tips for viewing the Hunting Management Units on the Map page of the Garmin.
Things to keep in mind:
- Hunting Management Units (HMU) have multiple names depending on the state chosen*
- All Hunting Management Units are show with green lines if multiple units are selected at the same time it may be difficult to view the data
- Only Units available for the state will be shown - example there won't be an option for alligators in Montana
- Some states do not group all species into specific the units - example Oregon has 3 units; Duck, Goose and all other species are grouped together
- The unit number will display at the top of the Map page if the area is highlighted
To Enable Hunting Management Units:
- Open the Main Menu
- Press Setup
- Press Map
- Press HMU Setup
- Press the State
- Press the Unit(s) to view
- Press Page
The Hunting Management Unit(s) chosen should be visible on the Map page. You may have to zoom in or out depending on your view level.
HuntView Plus maps have a lot of information. Quite often with Hunting Management Units enabled the Map page on the Garmin may become very difficult to read.
Tips for viewing Hunting Management Units on a Garmin:
- Only enable the Hunting Management Unit currently needed
- Disable other map information from HuntView Plus mapping
- Press Setup
- Press Map
- Press Map Information
- Select the Maps not needed to view - Tip: It is recommended to have at least the basemap enabled with the HMU mapping
*Alternative names for Hunting Management Units:
- Game Management Units (GMU)
- Wildlife Management Units (WMU)
- Hunting Zones
