Use the screwdriver to remove the screw under the weather cap.
Remove the screw retainer clip, screw, and damaged weather cap.
Tip over the Edge to remove any broken off weather cap material.
Place the new screw retainer clip onto the new weather cap rubber tip.
Insert the assembled weather cap to the back of the Edge.
Insert the new screw and tighten with the screwdriver.
Changing the USB Weather Cap on a Garmin Edge
Replacing the Weather Cap
A small Phillips screwdriver is needed for this process. Select your Edge® Cycling Computer for the correct steps.
Remove the washer, screw, and damaged weather cap.
Place the new screw through the washer and into the hole on the new weather cap.
Tighten the screw with the screwdriver.
Use the screwdriver to remove the screws on top of the weather cap.
Remove the screws and damaged weather cap.
Place the new weather cap in place.
Insert the new screws and tighten with the screwdriver.
