Using an In-hull Transducer in a Triumph Boat
In-Hull transducers will not work with Triumph boats. Triumph boat's hull consists of two Roplene layers. In between these two layers of Roplene is a foam filled center. Roplene is a form of plastic that will not allow the transducer's signal to pass through.
There are two options for installing a transducer on a Triumph boat.
- Thru-Hull
- Transom
NOTE: If a thru-hull transducer is chosen, please consult the boat's dealer or a professional installer. Repairing Ropelene can be very difficult if not impossible.
