1. Touch the app icon
2. Touch Navigation if necessary
3. Touch Trip Planner
4. Touch New Trip
5. Touch Select Start Location
Note: The Start Location refers to the first stop on the route.
6. Select the starting point using the various search options
7. Touch Select
8. Touch Add Location to add a second point
9. Follow steps 6 through 8 to locate and add more points. Each route can hold up to 30 points.
- Touch
to change the order of points.
- Touch and hold the
move icon next to a point and drag it to a location on the list.
- Touch the
wrench icon to change a location.
- Then repeat steps 6 and 7 to select the desired location.
- Touch the
delete icon to remove a point.
- Then touch Yes.
- Touch the
orange flag icon to change a waypoint into a
shaping point.
10. Touch Select Destination and follow steps 6 and 7 to select a destination
11. Touch Next. The route will now calculate
12. Review the route on the map. Touch the back arrow if any changes need to be made. Touch Save if no changes need to be made.
13. Type a name for the route and touch Done
The trip is now saved to Trip Planner and can be found under Saved Trips.
