"No Detailed Maps Found That Support Routing" or "No Map Data Available" Message on a Garmin Automotive Device
There may be a problem with the mapping files if the message “No Detailed Maps Found That Support Routing” is displayed after turning on an automotive device. The message “No Map Data Available” may display when searching for a destination. This may cause the device to show only the locations of major cities or major highways with no side streets.
To Correct This Issue:
For “No Detailed Maps Found That Support Routing” - if it cannot be dismissed by pressing OK or the back button, press and hold your finger on the message to clear it
For “No Map Data Available” - Ensure the map is enabled on the device by following the steps below.
1. Touch Settings
2. Touch Map & Vehicle
3. Touch myMaps
4. Enable the maps
- The map is enabled if a checkmark is present.
- Touch the empty box if a checkmark is missing.
Contact Product Support for further assistance if the map is missing from the myMaps screen or the above does not resolve your issue.
