Forerunner 10
Forerunner 50
Forerunner 101
Forerunner 110
Forerunner 201
Forerunner 205
Forerunner 210
Forerunner 220
Forerunner 301
Forerunner 305
Forerunner 405
Forerunner 405CX
Forerunner 410
Forerunner 610
Forerunner 620
Forerunner 910XT
What Is the Activity Class Measurement in Garmin Connect?
NOTICE: The activity class setting applies to older Garmin devices and does not affect the measurement readings on newer devices. Improved algorithms have negated this setting from being used on newer products despite the it still being visible in Garmin Connect. For more details on devices that use this feature see the section "Which Garmin Devices Use Activity Class?" in this FAQ.
Activity Class is a setting in the Garmin Connect™ application that allows you to adjust the frequency and how long you train in a given week. This measurement falls on a scale from zero to 10 as shown in the image below.
Adjusting this setting to the appropriate level along with accurate user profile information will help improve the accuracy of calories burned during a given activity for these models.
For help with adjusting this setting see: Changing the Activity Class Setting in Garmin Connect
Select an option below to reveal a list of Garmin products that utilize the activity class setting in Garmin Connect.
