What Can I Use to Charge My Garmin Approach
When charging the battery of your Garmin Approach® golf device, we recommend using an available USB port on a personal computer or a USB wall charger, and avoid using inexpensive off-brand chargers.
If you do not have a Garmin charger you can use any of the following:
  • Charger for your phone
  • Wall outlet with USB charging ports
  • A wall charger from a reputable brand name should be fine.  Ensure the wall charger features the registered UL marks indicating that the item was manufactured in compliance with UL's safety requirements.  For more information about UL marks please see: UL Marks for North America
NOTE: Damage to a device as a result of using a non-UL-certified AC charger or cable will not be covered under warranty.
