Showing or Hiding Garmin Explore Tracks, Routes, and Waypoints After Enabling Garmin Explore Support
You can choose which collections of tracks to show or hide on the device when Garmin Explore™ is enabled. If Garmin Explore has not been enabled, view the steps below for your device.
To enable the Garmin Explore on the zūmo® XT GPS navigator, see Syncing, Adding, and Deleting Explore App Data on the zūmo XT.
To enable the Garmin Explore on the zūmo® XT2 GPS navigator, see Syncing, Adding, and Deleting Garmin Explore™ Data on the zūmo XT2 GPS Navigator.
To enable the Garmin Explore on the Tread®, Tread® - Base Edition, and Tread® Textron GPS navigators, see Syncing, Adding, and Deleting Explore App Data on the Tread.
To enable the Garmin Explore on the Arctic Cat G8 Display, Kawasaki RIDGE 8" Tread Display, Tread® XL - Baja Chase Edition, Tread® XL - Baja Race Edition, Tread® - Overland Edition, Tread® - SxS Edition, and Tread® - XL Overland Edition GPS navigators, see Syncing, Adding, and Deleting Explore™ Data on a Tread Device.
NOTE: Update your device software if the steps below do not work on your device.
To Choose Which Collections of Tracks and Waypoints to Show or Hide on the Tread XL - Baja Chase Edition and Tread XL - Baja Race Edition:
- Touch Apps
- Touch Tools
- Touch Settings
- Touch Map Display
- Touch Map Layers
- Touch Collections
- Select the collections to show on the map and touch Save
To Choose Which Collections of Tracks, Routes, and Waypoints to Show or Hide on all other Devices:
- Touch Settings
- Touch Map & Vehicle or Map Display
- Touch Map Layers
- Touch Collections
