Simulating a Route on a Tread SxS Edition, Tread Overland Edition, and Tread XL Overland Edition
Simulating a route allows you to see how the device will navigate you without actually driving the route; the vehicle icon will move and the device will speak the turn instructions. This feature is useful when you are in a location where a satellite signal cannot be accessed or for calculating a planned route.
To simulate a route on an automotive device, the GPS Simulator must be turned on.
To Turn GPS Simulator on:
  1. Touch Settings
  2. Touch Personal
  3. Touch Location to turn it off
You may now use the device to simulate a route to a given destination.
To Simulate a Route From a Different Starting Point Than Your Current Location:
  1. Go back to the main menu
  2. Touch the   Stop icon to stop any current routes
    • If this button is greyed out, the device currently does not have a route active, and you will be able to simulate a route.
  3. Touch Where To?
  4. Locate and select the starting point (address, POI, city, intersection, etc.)
  5. Touch the  info button
  6. Scroll down and touch Set Location
The device will now indicate your current location is the location entered in step four. To simulate a route from that set location, return to the main menu, and enter the destination. When asked if you would like to simulate driving the route, touch Yes.
Note: If the two locations are separated by the ocean (e.g., starting in the US and attempting a route simulation to a point in Europe), the device will attempt the calculation but will not succeed. Instead, it will return an error stating that it cannot calculate the route. This can be corrected by placing both points on the same continent.
