Installing Xero X1i Crossbow Scope Replacement Lock Screw
Depending on your crossbow model you may have clearance problems with the factory lock knob. Garmin offers a replacement lock screw with a lower profile for more clearance.
Installing Replacement Lock Screw
- Remove Lock Knob.
- The kit comes with a male and female washer that need to be paired with the male end into the female end.
- Place the female washer against the mount body, and the male on the screw head side.
- Insert lock screw with washer into the mount.
- Tighten lock screw to 12 lbf-in.
NOTE: It is suggested to use a torque wrench rated to 12-in lbs.
