Clarion M502 Software Update
M502 Improvements (09/22/2016)
  • Radio channel search improvement
  • Bluetooth update
  • Wired remote update
Includes M502 Improvements (09/22/2016)
  • • Wired remote stability
Includes M502 Improvements (12/31/2013)
  • • iPod no longer continues to play when changing modes
  • • Pandora no longer continues to play when changing modes
  • • ”RECEIVED CALL" and MISSED CALL" list are displayed correctly
  • • The incoming call information is displayed correctly
Includes M502 Improvements (03/25/2013)
  • • Bluetooth audio streaming (A2DP) iPhone 5 and Apple iOS 6 devices
Includes M502 Improvements (09/27/2012)
  • • USB playback stability
Includes M502 Improvements (07/09/2012)
  • • Bluetooth audio streaming (A2DP) volume level issue when the source is changed from A2DP to Bluetooth hands-free profile (HSP) or tuner mode
  • • Bluetooth hands-free operation
Estimated Update Time: 35 minutes
Introduction
Download and print this M502 Software Update procedure prior to downloading and installing this software update.  It is important that this procedure is done in the order described in this document as failure to do so may result in the M502 becoming inoperable.
Confirm the software version of your unit prior to performing the update. Refer to step “3. Confirm Result” at the end of this document. If the software version on your device matches the versions listed in step “3. Confirm Result”, then your M502 is up to date and you do not need to perform the software update.
Warning: Do not perform this software update while operating the vehicle. Do not interrupt the power of the M502 while the update is in progress. Remember to record all the “Settings” prior to performing the update process, as the unit will return to factory default settings after the update.
Requirements
  • A Windows PC with an internet connection and a Zip/Unzip program installed into it. (http://winzip.com/downwz.htm). Note that the PC will need to be accessed throughout the update process, as files will need to be loaded and deleted from the USB memory device.
  • A blank USB memory device with 256MByte or greater of memory.
  • Access to the USB port on the M502.
Preparation
Download the “M502.zip” file below and save it to your computers desktop. The file is zip-compressed and it will need to be unzip it onto your PC prior to copying the files to a USB memory device.
When the file is unzipped, you will see five files.
  • cdrom.bin (604kByte)
  • M502MCU.BIN (193kByte)
  • boot.bin (35kByte)
  • updater.plf (146kByte)
  • firmware.plf (1,647kByte)
Update
  1. Copy the “cdrom.bin” file to a blank USB memory device from your PC.
    • cdrom.bin
  2. With the M502 powered on, insert the USB memory device into the USB port.  The unit will automatically recognize the USB memory device and show “SERVO UPGRADING” on the display.
  3. Once the M502 has switched to the tuner mode, remove the USB memory device.
  4. Plug the USB memory device into your PC and delete the “cdrom.bin” file it contains.
  5. Now, copy the “M502MCU.BIN” file to the USB memory device.
    • M502MCU.BIN
  6. With the M502 powered on, insert the USB memory device into the USB port. The unit will automatically recognize the USB memory device and show “MCU UPG” on the display.
  7. Once the process has completed, please remove the USB memory device from the M502.
  8. Plug the USB memory device into your PC and delete the “M502MCU.BIN” file it contains.
  9. Now, copy the “boot.bin”“updater.plf”, and “firmware.plf” files on to the USB memory device.boot.bin, updater.plf, firmware.plf
  10. Power up the M502.
  11. Insert the USB memory device into the USB port. The M502 will automatically recognize the USB memory device and show “BT UPDATE FILE1   ***%” on the display. Once FILE1 reaches 100% “BT UPDATE FILE2   ***%” will be displayed on the screen. Once FILE2 reaches 100% “BT UPDATE FILE3   ***%” will be displayed on the screen.
  12. Once the process has completed, please remove the USB memory device from the M502.
NOTE:
• Do not interrupt the file transfer process. The M502 will automatically switch to the tuner mode when the file transfer is complete.
• Do not interrupt the file transfer process. The M502 will automatically turn off when the file transfer is complete.
• Do not interrupt the file transfer process.  The M502 will automatically turn off when the file transfer is complete. This portion of the update may take longer than five minutes.
Confirm Result
  1. Power up the M502 then, while in tuner mode, press the Play/Pause button on the remote three times. Confirm that the version reads “VM-0706-1U”.
  2. While in iPod mode, press the Band button on the remote three times. Confirm that the version reads “VS-0108”.
  3. While in AUX mode, press the Play/Pause button on the remote three times. Confirm that the version reads “SW01.57.00”.
NOTE: If any of the software versions do not match, please perform the software update again.
M502.zip (2 MB)
Related
