The Time on My vivofit Jr. Series Watch Is Wrong
vivofit jr., vivofit jr. 2, and vivofit jr. 3 watches update the time and date each time you sync with the Garmin Jr. app.
To Update the Time on Your Device:
  1. Bring the device close to your smartphone that the Garmin Jr. app is installed on.
  2. Open the Garmin Jr. app.
  3. On the vivofit jr. device, hold the key until you see Signal bars on the screen.
  4. On your smartphone, swipe down to refresh the app.
Once connected you will see a syncing icon: Two arrows circling each other which indicates that the watch is communicating with the app through your smartphone. Once complete, the time on the watch should be correct.
The Time on the Vivofit Jr. is Still Wrong
If you still see the wrong time on the watch, ensure the following:
  1. The time and date on the smartphone is correct.
  2. If the time on your device updates but is incorrect on a regular basis this may signal the need to change the batteries. See the following for help: Replacing the battery on a vivofit jr. device.
  3. If the time on your device is still incorrect and data is not syncing, the device may need to be removed and reconnected (see Garmin Jr. App Bluetooth Troubleshooting for instructions).
