Changing the Track Color on the Rino 750, 750t, and 755t
On the Rino® 750, 750t, and 755t outdoor handhelds you can change the color of individual tracks. You can also change the default track color that is used for the current track.
NOTE: The user interface on the Rino 750, 750t, and 755t is set to Classic Mode by default, but it can be changed to Activity Mode by going to the app drawer and selecting Setup > System > Mode. These devices also record files in an activity format (FIT) by default. If you need the handheld to record files as tracks (GPX), open the app drawer and select Setup > Recording > Advanced Setup > Output Format > Tracks (GPX/FIT).
Changing the Color of Saved Activities or Tracks
  1. Open the app drawer.
    • Activity Mode: Press Power Button.
    • Classic Mode: From the home screen, swipe bottom to top in portrait mode or left to right in landscape mode.
  2. Select Activity History or Track Manager.
  3. Select the Current Activity, Current Track, or a saved activity or track.
    • Additional Steps for Archived Tracks:
      1. Select Archived Tracks.
      2. Select the track you want to change.
      3. Select Lowercase i.
      4. Tap Gray Star.
  4. Select Lowercase i.
  5. Select Color.
  6. Select the desired color.
  7. If necessary, select Show on Map to toggle this setting on.
Now while on the Map page, the track will appear as the newly selected color.
Changing the Color of Contact Tracks
  2. Select Track Manager.
  3. Select Contact Tracks.
  4. Select a contact.
  5. Select Set Color.
Now while on the Map page, the contact's track will appear as the newly selected color.
