Safely Ejecting Your Garmin Device From a Computer
Safely removing your device before unplugging it from a computer is a typically recommended process to follow. This is especially important after updating the device or sending data to a device. The write-caching feature on some computers may not have completely built or transferred the data to the device even though the transfer appears to be complete. Properly ejecting the device ensures all the information has been transferred.
Choose your computer platform below to reveal instructions to follow.
NOTE: Not all devices may have a safely eject option.
Mac Instructions
1. Open Finder.
two-faced finder icon
2. Select Go in the menu bar.
Go in the toolbar
3. Select Computer.
Computer from GO Dropdown
4. Drag the Garmin device to the Trash to safely remove it.
Trash Icon on Mac
If the steps above do not apply to your MacOS refer to the macOS User Guide.
Windows 7/8 Instructions
1. Select the triangle to show hidden icons.
 Triangle Icon
2. Right-click the Safely Remove Hardware icon.
 USB Hardware Eject Icon
3. Select Eject GARMIN or Eject Device.
4. Wait for Windows to display the message "Safe to Remove Hardware" before unplugging the device.
Windows 10 Instructions
1. Select the arrow to show hidden icons.
 Arrow Icon
 USB Eject Icon
Windows 11
  1. Look for the Safely Remove Hardware icon on the taskbar. If you don't see it, select Show hidden icons . Press and hold (or right-click) the icon and select the hardware you want to remove.
    Eject Symbol Windows 11 Screenshot
  2. If you can't find the Safely Remove Hardware icon, press and hold (or right-click) the taskbar and select Taskbar settings Black and White Gear Outline.
  3. Select Taskbar corner overflow to expand it. Scroll to Windows Explorer (when you hover over it, the tooltip will read Safely Remove Hardware and Eject Media) and turn it on.
  4. If this doesn't work, make sure the device has stopped all activity like copying or syncing files. Select Start Black Windows Start Icon > Settings Black Gear Symbol > Bluetooth & devices Bluetooth Symbol > Devices Windows 11 Devices Icon.
  5. Select your device, and then select Remove this device.
  6. Finally, check with the hardware manufacturer for new drivers or other updates.
On Garmin Device
Some Garmin devices have the option to eject from the computer in mass storage mode and remain plugged in to charge. Select the button next to where you see eject icon on the screen.
