Navionics Boating: Raymarine Dragonfly PRO and Wi-Fish Sonar Settings
The Raymarine Dragonfly PRO and Wi-Fish™ Sonar Settings allow you to make sonar adjustments.
Tap the sonar adjustment icon to the far left to change:
  • Sensitivity: Set Gain, Contrast and Noise filter manually or choose automatic mode.
  • Range: Choose automatic or manually set the lowest value (Shallow) and the highest (Deep).
  • Options:  Select your preferred color palette for graph or turn “Depth lines” on/off.  Turn A-Scope on/off to instantaneously display the echoes found in the transducer’s acoustic beam.
  • Settings: Adjust Depth Offset by setting the distance from the transducer to either the waterline (below waterline) or the keel (above waterline).
