Approach® S50 watch
Approach® S70 | Approach® S70 - TaylorMade® Edition watches
D2™ Air X15 watch
D2™ Mach 1 | D2™ Mach 1 Pro watches
D2™ Mach 2 watch
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition watches
Descent™ G2 watch
Descent™ Mk3 | Descent™ Mk3i watches
Edge® 540 |Edge® 540 Solar cycling computers
Edge® 550 cycling computer
Edge® 840 | Edge® 840 Solar cycling computers
Edge® 850 cycling computer
Edge® 1040 | Edge® 1040 Solar cycling computers
Edge® 1050 cycling computer
Edge® Explore 2 cycling computer
Edge® MTB cycling computer
Enduro™ 2 watch
Enduro™ 3 watch
epix™ (Gen 2) | epix™ (Gen 2) Sapphire | epix™ (Gen 2) Porsche Edition watches
epix™ Pro (Gen 2) Standard | epix™ Pro (Gen 2) Sapphire watches
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition watches
fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED Edition
fēnix® E watch
Forerunner® 165 | Forerunner® 165 Music watches
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music watches
Forerunner® 265 | Forerunner® 265S watches
Forerunner® 570 watch
Forerunner® 945 | Forerunner® 945 LTE watches
Forerunner® 955 | Forerunner® 955 Solar watches
Forerunner® 965 watch
Forerunner® 970 watch
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition watches
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition watches
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition watches
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition watches
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition watches
Instinct® 3 - AMOLED | Instinct® 3 - Solar watches
Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar watches
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition watches
Instinct® Crossover AMOLED | Instinct® Crossover AMOLED - Tactical Edition
Instinct® E watch
Lily® 2 | Lily® 2 Classic | Lily® 2 Active watches
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2) watches
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition watches
quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7 - Solar Edition watches
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® - Pro Ballistics Edition watches
tactix® 8 - AMOLED | tactix® 8 - Solar watches
Venu® Sq 2 | Venu® Sq 2 - Music Edition watches
Venu® 3 | Venu® 3S watches
Venu® 4 watch
Venu® X1 watch
vívoactive® 5 watch
vívomove® Trend watch
vívosmart® 5 watch
vívoactive® 6 watch
Changing Device Settings in the Garmin Connect App
You can use the Garmin Connect™ app to adjust settings on your compatible Garmin® watch or bike computer. The app connects to your device using Bluetooth® to instantly update things like display options, sounds and alerts, and data screens.
For features not available in the app, check your owner's manual for instructions on how to change those settings directly on your device.
Changing Device and User Settings in Garmin Connect App
NOTE: Some settings can only be changed directly on the Garmin device, in which case you may receive an "Update Setting on Device" prompt.
Open the Garmin Connect app.
Select More (bottom right).
Select Garmin Devices.
If you have more than one device, select the device you would like to make changes to.
Select an option to edit (such as User Profile to set heart rate zones, or Activities & Apps to change data fields for activities).
Make the desired changes.
The changes will be reflected immediately on the device.
Video Tutorial
Real Time Setting Changes via the Garmin Connect App
