Powered Magnetic Mount with HD Traffic
The dēzl™ OTR800, dēzl™ OTR810, dēzl™ OTR820, dēzl™ OTR1000, dēzl™ OTR1010, dēzl™ OTR1020, RV 890, RV 895, RV 1090, and RV 1095 are compatible with a Powered Magnetic Mount with HD Traffic. These devices are not compatible with any GTM Traffic Receiver cables.
- An HD traffic receiver is embedded in the mount
- Along with traffic information, it provides basic weather information including current temperature and a 6-day forecast
- The mount uses the vehicle power cable included with the device
- This mount includes a 3.5 mm stereo AUX out jack
- A 3.5 mm male-to male stereo audio AUX cable (not included) can be used to send navigation audio to your car stereo aux input or to wired headphones
- Media playing on your phone will not be sent via the AUX output, as the device is acting as an extended display only when paired via Bluetooth to your smartphone
- The 1.0 AMP USB port on the magnetic mount can be used to power a compatible Garmin Dash Cam
- This USB port is not designed to charge third-party devices like smartphones and tablets
- Connecting a splitter or hub to this USB port may cause the device to shut down
- See Using the USB Port on the Magnetic Mount for more information
- This mount also includes a 3.5 mm composite video input jack which can be used with third-party wired backup cameras
- NTSC and PAL format cameras are required. See Automotive GPS Devices that Can Add a Backup Camera for more information
- A 6.5 foot AV Adapter Cable is included in the box
