Garmin Devices Not Compatible with BaseCamp
BaseCamp™ software supports a wide range of Garmin devices. However, there are some specific devices that are not compatible with BaseCamp, which are listed below.
Garmin Serial Handhelds
Legacy Garmin devices that communicate with the computer through a serial port are not compatible with BaseCamp.
eTrex® Basic
eTrex® H
eTrex Vista™
eTrex Legend™
eTrex Venture™
eTrex Mariner™
eTrex Summit™
eTrex Camo™
Foretrex® 101 and 201
Geko™ 201 and 301
Rino® 110, 120, and 130
GPS 72 and 76
GPSMAP® 76 and 76S
GPS 12, 12MAP, 12CX, and 12XL
GPS II™
GPS II+
GPS III®
GPS III+
GPS V™
Use MapSource to communicate with a device in this list. If you encounter a "Previous MapSource Not Found" error this can be resolved by installing BaseCamp first, then running the MapSource install file again. While these devices are not directly compatible with BaseCamp, installing the program will load the necessary background files required for MapSource to install and run on the computer.
The Trip and Waypoint Manager software that was included with the retail purchase of many of these devices has since been discontinued and is no longer available.
Garmin Automotive Devices
dēzl™ LGV620 | dēzl™ OTR620 GPS navigators
dēzl™ LGV720 | dēzl™ OTR720 GPS navigators
dēzl™ LGV820 | dēzl™ OTR820 GPS navigators
dēzl™ LGV1020 | dēzl™ OTR1020 GPS navigators
dēzlCam™ LGV725 | dēzlCam™ OTR725 GPS navigators with camera
Tread® 2 GPS navigator
To view and share your data, use the Tread® App. BaseCamp will display "Unsupported Device Connected".
zūmo® XT2 GPS navigator
Earthmate Compatible inReach Devices
The following devices are not compatible with BaseCamp, but can be used with the Earthmate app and the Garmin Explore™ website to manage routes, waypoints, and tracks.
inReach® Mini
inReach Explorer® +
inReach SE® +
inReach Explorer®
inReach SE®
inReach® Original Devices (inReach for PN-60w, inReach for Android, or inReach for Smartphones)
Garmin In-Dash Navigation Systems
Garmin BaseCamp is not compatible with planning routes or sharing locations with Garmin in-dash navigation systems.
Garmin MTP Mode Devices (Mac)
The following Garmin MTP (Media Transfer Protocol) devices are not compatible with BaseCamp on Mac computers, but are compatible with BaseCamp on Windows computers. For more information, see - Using Newer GPSMAP, Montana, Foretrex, and eTrex Series Devices With BaseCamp on a Mac.
Alpha® 300
Alpha® 300i
eTrex® SE
eTrex® Solar
Foretrex® 801
Foretrex® 901
GPSMAP® 67
GPSMAP® 67i
Montana® 710
Montana® 710i
Montana® 760i
