BaseCamp Software Fails to Install on a Windows Computer
When installing BaseCamp™ software to a Windows computer, there may be obstacles that can prevent the installation from completing successfully. When this occurs, an error message such as Install Failed may display or the installer may not launch.
NOTE: If Garmin BaseCamp software was installed previously, see .msi File Not Found when Updating a Garmin Software Application.
Try the Following Solutions:
NOTE: Shutting down, pressing the power button, or closing the lid on a notebook computer may not effectively restart the computer on some operating systems. Follow the instructions below to ensure that the computer is completely restarted.
Windows 10 and Newer
- Right-click the
Start button
- Click Power
- Some computers may skip this step.
- Click Shut down or sign out
- Click Restart
- Right-click the
See below for a Windows 10 example.
Install the latest Microsoft Windows Updates
Microsoft has released Windows updates that may resolve issues with Garmin applications. For more information about installing these updates, see the How do I keep my PC up to date? section of Microsoft's Windows Update FAQs page: Windows Update: FAQ.- Right-click the downloaded Garmin BaseCamp software installer file
- Click Properties
- Click the General Tab
- Click the Unblock button if present
- If there is no Unblock button, the installer is not blocked.
- Click OK
Run Garmin the Garmin BaseCamp™ Software as an Administrator
The error may be caused by permissions issues for Garmin BaseCamp. Running the application as an administrator may resolve this:1. Locate and right-click the Garmin BaseCamp icon in one of the following locations (examples from Windows 10 pictured):
Search for Garmin BaseCamp in the Start menu.
Find the desktop shortcut (if present).
2. Click Run as Administrator
If opened from the Start menu in Windows 10 or newer, mouse over More, then click Run as administrator.
If prompted to allow Task Manager to make changes to your computer, click Yes.
If using Windows 7, click Processes.
- If using Windows 8.1 and later, click More Details, then Details.
2. End any processes named msiexec.exe
Note: Before uninstalling BaseCamp software, you can backup all your data into a single archive file which you can restore after re-installing the program. For steps, see: Backing Up Data and Restoring Backup Data.
- See Uninstalling Garmin BaseCamp for steps.
After these instructions are followed, Garmin BaseCamp software should be able to install successfully. If not, the computer should be checked by a Microsoft certified repair technician, or another computer should be used.
