Using an ECHOMAP to Configure a Garmin Autopilot without a GHC
The following ECHOMAP devices can be used to commission a Garmin Autopilot without a GHC
ECHOMAP CHIRP 5x / 7x / 9x
ECHOMAP Plus 6x / 7x / 9x
ECHOMAP UHD 6x / 7x / 9x
ECHOMAP Ultra Series
ECHOMAP UHD2 7x / 9x
ECHOMAP Ultra 2
NOTE: For GPSMAP series devices, see Related Content below.
Accessing Autopilot Commissioning on Compatible ECHOMAP
From the main screen select, Home > Settings > My Vessel > Autopilot Installation Menu > OK > Wizards > Dockside Wizard or Sea Trial Wizard follow the onscreen prompts
NOTE: Depending on the specific Autopilot system and configuration, the user may have to assign GPS and Speed sources, calibrate a feedback sensor, verify tachometer, test steering direction, and more. For more details and specifics refer to the applicable Garmin Autopilot Installation, Configuration and Owners manuals.
