AutoShot and Other Features on Garmin Golf Watches and Devices
The AutoShot feature measures and auto-records shot distances by detecting the swing speed and impact with the ball. Scoring must be enabled for the round to use the AutoShot feature. The watch must be on the correct hole when teeing off and the score must be entered for each hole prior to teeing off on the following hole. The watch also must be worn on your lead wrist.
After completing play, you can view a post-round analysis in the Garmin Golf™ app or Garmin Connect™ app. In order to upload AutoShot data, the Garmin product needs to be paired with a compatible smartphone, the Garmin Connect app, and the Garmin Golf app, or it can be uploaded through Garmin Express™.
Devices Compatible With AutoShot
  • Approach® S20
  • Approach® S40
  • Approach® S42
  • Approach® S44
  • Approach® S50
  • Approach® S60
  • Approach® S62
  • Approach® S70 - 42mm | Approach® S70 - 47mm | Approach® S70 - TaylorMade® Edition - 47 mm
  • Approach® X40
  • D2™ Air
  • D2™ Air X10
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk1
  • Descent™ Mk2 | Descent™ Mk2S | Descent™ Mk2i
  • Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm | Descent™ Mk3i – 51 mm
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition 47 mm
  • epix™ Pro (Gen 2) - Standard Edition 42 mm| epix™ Pro (Gen 2) - Sapphire Edition 42 mm
  • epix™ Pro (Gen 2) - Standard Edition 47 mm| epix™ Pro (Gen 2) - Sapphire Edition 47 mm
  • epix™ Pro (Gen 2) - Standard Edition 51 mm| epix™ Pro (Gen 2) - Sapphire Edition 51 mm
  • fēnix® 5S | fēnix® 5 | fēnix® 5X
  • fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 570
  • Forerunner® 935
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • Legacy Hero - Captain Marvel | First Avenger
  • Legacy Saga - Darth Vader™ | Rey™
  • Lily® 2 Active
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 5 | quatix® 5 Sapphire
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • quatix® 7 Pro
  • tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Charlie
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu®
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq | Venu® Sq - Music Edition
  • Venu® Sq 2 | Venu® Sq 2 - Music Edition
  • Venu® X1
  • vívoactive® 3 | vívoactive® 3 Music
  • vívoactive® 4 | vívoactive® 4S
  • vívoactive® 5
  • vívoactive® 6
Add Shot Manually
Add Shot allows you to manually record a shot if AutoShot does not pick it up. The shot placement will appear in the AutoShot section of the scorecard like automatically detected shots.
Devices Compatible With Add Shot
  • Approach® S40
  • Approach® S42
  • Approach® S44
  • Approach® S50
  • Approach® S60
  • Approach® S62
  • Approach® S70 - 42 mm | Approach® S70 - 47 mm | Approach® S70 - TaylorMade® Edition - 47 mm
  • Descent™ G2
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • fēnix® E
  • Forerunner® 570
  • Forerunner® 965
  • Forerunner® 970
  • Lily® 2 Active
  • quatix® 7 Pro
  • Venu® X1
Club Prompt
You can use the Club Prompt feature to select which club was used after each shot. This allows the you to track how far shots have traveled and begin to gather club distance averages.
Devices Compatible With Club Prompt
  • Approach® G80
    NOTE: Club Prompt only available when using Measure Shot.
  • Approach® S20
  • Approach® S40
  • Approach® S42
  • Approach® S44
  • Approach® S50
  • Approach® S60
  • Approach® S62
  • Approach® X40
  • D2™ Air
  • D2™ Air X10
  • Descent™ G2
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • fēnix® E
  • Forerunner 570
  • Forerunner® 965
  • Forerunner® 970
  • quatix® 7 Pro
  • Venu®
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
For products that do not have the Club Prompt feature, you can edit the clubs on the saved scorecard via Garmin Connect or the Garmin Golf app steps below.
Adding Clubs to Shots on Saved Scorecards in Garmin Connect Website
  1. Sign into your Garmin Connect account from a personal computer.
  2. Select Golf from the navigation bar on the left.
  3. Select Scorecards.
  4. Select a scorecard.
  5. Select the score for the hole.
  6. Select Edit/Add Shots.
  7. Select the three_dots_Garmin_Connect next to the shot to edit.
  8. Select Edit Club.
  9. Select a club.
  10. Select Select.
Adding Clubs to Shots on Saved Scorecards in Garmin Golf
Garmin Golf (Android)
  1. Select Activity.
  2. Select a scorecard.
  3. Scroll down and select the hole to change the club for.
  4. Select the shot to be edited.
  5. Select a Club.
  6. Select Done.
Garmin Golf (iOS)
  1. Select Activity.
  5. Select a Club.
  6. Select Done.
Scoring
When scoring is enabled, you are prompted to enter your score when you finish the hole. You can adjust the score manually at any time during a round. The scoring feature will automatically default to par and you need to adjust the score manually on the watch after each hole. However, if you use the AutoShot feature and a combination of either Club Prompt with the CT10 Starter Pack or the Full Set of CT10 sensors, the device will attempt to estimate your score for each hole.
Devices Compatible With Keeping Score
  • All Approach Watches & Handhelds
  • D2™ Air
  • D2™ Air X10
  • Descent™ G2
  • Descent™ Mk1
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • fēnix® 3
  • fēnix® E
  • Forerunner® 570
  • Forerunner® 935
  • Forerunner® 965
  • Forerunner® 970
  • Lily® 2 Active
  • quatix® 7 Pro
  • tactix® Charlie
  • Venu®
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
  • vívomove® HR
Stat Tracking
When you enable statistics tracking on the device, you can track how many putts per hole, fairways in regulation, penalties per hole, and greens you hit in regulation. You can compare rounds and track improvements using the Garmin Golf app.
Devices Compatible With Stat Tracking
  • Approach® G3
  • Approach® G5
  • Approach® G6
  • Approach® G7
  • Approach® G8
  • Approach® G12
  • Approach® G30
  • Approach® G80
  • Approach® S4
  • Approach® S5
  • Approach® S6
  • Approach® S12
  • Approach® S20
  • Approach® S40
  • Approach® S42
  • Approach® S44
  • Approach® S50
  • Approach® S60
  • Approach® S62
  • Approach® X10
  • Approach® X40
  • D2™ Air
  • D2™ Air X10
  • Descent™ G2
  • Descent™ Mk1
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • fēnix® E
  • Forerunner® 570
  • Forerunner® 935
  • Forerunner® 965
  • Forerunner® 970
  • quatix® 7 Pro
  • tactix® Charlie
  • Venu®
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
CT10 Sensors
The CT10 sensors, when attached to all (14) clubs, will replace the need for Club Prompt. Also, AutoShot is limited and cannot detect slower swing speeds or softer impact. Therefore, shots like putts, chips, and short wedges are normally not recorded. The CT10 sensors, when attached to the putter and wedges, fill the gap left by AutoShot.
Devices Compatible With CT10 Sensors
IMPORTANT: Approach G12 and Approach S12 require a full set of Approach CT10 sensors for AutoShot detection. Clubs are tracked for each shot automatically with the paired sensors.
  • Approach® G12
  • Approach® S12
  • Approach® S20
  • Approach® S40
  • Approach® S42
  • Approach® S44
  • Approach® S50
  • Approach® S60
  • Approach® S62
  • D2™ Air
  • D2™ Air X10
  • Descent™ G2
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • fēnix® E
  • Forerunner® 570
  • Forerunner® 935
  • Forerunner® 965
  • Forerunner® 970
  • quatix® 7 Pro
  • Venu®
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
Related
