Using Multiple Garmin Dash Cams with Parking Mode Cables
Multiple Garmin Dash Cam™ driving recorders can be connected to a vehicle using Parking Mode cables if desired.
Each dash cam will require it's own cable, which can be used interchangeably (see compatibility below).
- For most Garmin Dash Cams: Parking Mode cable with microUSB connector.
- For the Garmin Dash Cam™ X110, Garmin Dash Cam™ X210, Garmin Dash Cam™ X310, and Garmin Dash Cam™ Mini 3: Parking Mode cable with USB-C connector.
NOTE: Using multiple Parking Mode cables will put more workload on the vehicle's battery, so the dash cam may not be able to stay on as long. For more information see The Impact of the Garmin Dash Cam's Parking Mode on a Vehicle's Battery.
