Needs to be on the latest software. See - Installing the Latest Software and Course Updates to the Approach Z82.
The Approach Z82 needs to be paired with the Garmin Golf app.
The Garmin Golf app must have location permissions set to Always.
- The Approach Z82 needs to have been powered on to save the last known location.
Using the Find My Gear Feature on the Garmin Golf App
If you misplace a compatible Garmin device or a golf club equipped with an Approach® CT10 sensor during your round, you can use the Find My Gear feature to view the last known location. After pairing your compatible device with the Garmin Golf™ app, a popup will appear in the app with the new Find My Gear features available.
What Gear Can Be Found Using Find My Gear?
The Find My Gear feature allows you to view the last known location of the following devices:
Approach® CT10 club tracking sensors
NOTE: Find My Gear can only locate three golf clubs equipped with Approach CT10 sensors at a time.
Approach® Z30 range finder
Approach® Z82 range finder
Finding Your Gear
Open the Garmin Golf app.
Select Profile.
Select My Devices.
Select Find My Gear.
NOTE: If needed, you may see "Go to Settings" to manage permissions for the Garmin Golf app. Location permission set to Always is required.
Your tracked gear will now appear on the map with a last known location, your distance from that location, and the time the gear was located there. Force closing the Garmin Golf app on an iOS phone may interfere with the Find My Gear feature.
Requirements for Find My Gear
Select an option below to see the requirements.
A round of golf must be recorded with one of the following watches:
Approach® S70 | Approach® S70 - TaylorMade® Edition
MARQ® Golfer (Gen 2)
Compatible watches and Approach CT10 sensors need to be on the latest software:
Compatible watches need to be paired with the Garmin Golf app.
Approach CT10 sensors must be actively paired to the watch throughout the entire round.
Needs to be on the latest software. See Updating Software on an Approach Z30.
The Approach Z30 needs to be paired with the Garmin Golf app.
The Approach Z30 needs to have been powered on to save the last known location.
