Mercedes-Benz® Metris/Vito - Smartphone Features
Mercedes-Benz® Metris/Vito vehicles have various smartphone features. Select a category below for more information:
Pairing a Phone
- Press TEL
- Select Connect Phone
- Select Add a device
- On your phone, enable Bluetooth wireless technology, and make your phone visible to other devices.
- TIP: See your phone's manual for more information
- On the infotainment system, select the name of your smartphone.
- Follow the on-screen instructions to complete the pairing process.
Removing a Paired Phone
- Press TEL
- Select
next to your paired phone
- Select Forget Device
Hands-Free Calling
Using Bluetooth wireless technology, the system can connect to your mobile phone to become a hands-free device.Placing a call:
- Press TEL
- Select an option:
- To dial a number, select
, enter the phone number, and select
- To call a contact from your phone book, select
, and select a contact
Receiving a Call:
When you receive a call, select Answer or Dismiss.
Using In-Call Options:
In-call options appear when you answer a call. Some options may not be compatible with your phone.
- To transfer audio to your phone, select
TIP: You can use this feature if you want to disconnect the Bluetooth connection and remain on the call, or if you need privacy.
- To use the dial pad, select
- TIP: You can use this feature to use automated systems, such as voice mail.
- To mute the microphone, select
- To hang up, select
Saving a Phone Number as a Preset:
You can save up to four contacts as presets on the dial pad. This allows you to quickly call your home phone number, family members, or frequently called contacts.
- From the phone screen, select Add Preset Contact
- Select a contact
Viewing Notifications
WARNING: Do not read or reply to notifications while driving.
- Select
- Select a notification
- Select
Connection Android AutoTM
- Verify the software on your Android smartphone is up to date
- Download and install the Android Auto app on your smartphone
- Using a compatible cable, connect your Android smartphone to USB 1 port in your vehicles
- Follow the on-screen instructions to complete the setup process
Connecting Apple CarPlayTM
- Verify the software on your Apple iPhone is up to date
- Using a genuine Apple cable, connect your Apple iPhone to the USB 1 port in your vehicle
