Managing Dash Cam Tandem Videos in the Garmin Drive App
You can view, save, share or delete Garmin Dash Cam™ Tandem videos in the Garmin Drive™ app. For instructions to connect your device with the Garmin Drive app see the owner's manual.
To View a Video:
 1. Launch the Garmin Drive app.
2. Select a Vehicle then touch Review Video.
NOTE: The Garmin Drive app will connect via the Tandem's built-in Wi-Fi. This may take a several minutes or multiple tries to connect. Click on Connect or Join when prompted.
Drive app Tandem Review Video
3. Select the desired video from the Gallery.
  • Videos will be categorized in Saved or Unsaved.
4. Select the desired camera view, Front or Interior.
To Trim, Export and Share a Video:
1. Select the desired video in the Gallery with the steps above.
2. Select the desired camera view, Front or Interior at the top.
3. Trim the video as desired by touching and dragging the arrows on either side of the timeline.
4. Touch Export to send the video to your phone's photos:
  • Export can take several minutes, depending on the length of the clip.
  • When finished, the app will show Export Complete 100%.
  • Exported video will be accessible in your phone's photos.
    • Trimmed videos will be accessible in your phone's photos while the original untrimmed video will remain in its original location, Saved or Temporary, in the Gallery.
5. To Export a Picture-in-Picture, select the camera view you want to add. If you only want to export a single video, select None. The Export may take several minutes depending on the length of the clip.
NOTE: To change the position of the Picture-in-Picture, touch the corner where you would like it to appear.
6. The video will then be exported and saved to the phone. To view the saved video touch Open in Photos.
See your phone's manual on how to share your saved videos on your phone with others.
To Delete a Video:
1. In the Gallery, touch Select at the top, or hold the video(s) you would like to delete.
2. Touch the ️ Trash Can icon in the lower right corner to delete the selected video(s), then touch Delete when prompted.
