Custom Waypoint Symbol Creation in BaseCamp
BaseCamp™ software comes with over fifty different waypoint symbols to choose from. If one of these symbols does not apply to the waypoint, a custom symbol can be made.
Custom symbols in BaseCamp cannot replace existing symbols, but new ones may be created.
NOTE: While BaseCamp and some devices are compatible with custom symbols, they are user-created and therefore we cannot guarantee or assist in their functionality with our program or devices.
Creating a Custom Symbol for BaseCamp
Before creating a custom symbol, ensure BaseCamp is up-to-date.
Ensure BaseCamp is closed.
Locate and install an image editing program.
Launch the image program.
Alter image as desired with the following requirements:
Width and height of the image must be 32x32 pixels.
Saved as a 24-bit Windows Bitmap (.BMP) or Portable Network Graphics (.PNG) file format.
Ensure the saved files use capital letters for the file extension; do not use lowercase extension letters.
Example use .BMP (not .bmp).
Saved named must be 000 through 063 (E.G., 044.BMP or 044.PNG).
Transparency is allowed by using the RGB color Magenta (255,0,255) or hex color code: ff00ff.
Save the image in the proper location:
Windows Vista, 7, 8 and 10 users - C:\Users\%USERNAME%\Documents\My Garmin\Custom Waypoint Symbols\
Mac users - Macintosh HD/Users/%USERNAME%/Library/Application Support/Garmin/Custom Waypoint Symbols/
If you do not see the Library option, it may be hidden. Press Command + Shift + . (period) to view the Library.
You can also access the Library through the BaseCamp menu by going to Edit > Manage Custom Waypoint Symbols > Show in Finder.
Close the image editing program.
The custom symbol is now ready to use next time you launch BaseCamp. New symbols will be grouped together under the Custom waypoint symbol list.
Custom symbols created for BaseCamp cannot be viewed on the device. If you would like the same custom symbols on the device, they need to be added to the device itself. Follow the steps below to add custom symbols to a device.
Saving a Custom Symbol to a Device
Plug the Garmin device into a computer.
Locate and open the drive for the Garmin device.
Windows users - Located under This PC, Computer, or My Computer.
Mac users - Located under Devices either on the desktop, or in the Finder.
Open the Garmin folder.
Save the custom symbol to the CustomSymbols folder.
NOTE: No more than 56 custom symbols can be saved on the device.
You should now be able to use the installed custom waypoint symbols on the Garmin device. See the following list to verify your device's compatibility.
Dakota® 10 | Dakota® 20
eTrex® 20 | eTrex® 20x | eTrex® 22x | eTrex® 30 | eTrex® 30x | eTrex® 32x
eTrex® Touch 25 | eTrex® Touch 35 | eTrex® Touch 35t
GPSMAP® 276Cx
GPSMAP® 62 | GPSMAP® 62s | GPSMAP® 62sc | GPSMAP® 62st | GPSMAP® 62stc
GPSMAP® 64 | GPSMAP® 64s | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx | GPSMAP® 64csx | GPSMAP® 64x
GPSMAP® 65 | GPSMAP® 65s
GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
GPSMAP® 67 | GPSMAP® 67i
GPSMAP® 78 | GPSMAP® 78s | GPSMAP® 78sc
GPSMAP® 79s | GPSMAP® 79sc
GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sci
Montana® 600 and all newer models in the Montana series
Oregon® 400 and all newer models in the Oregon series
Rino® 610 | Rino® 650 | Rino® 650t | Rino® 655t
Rino® 750 | Rino® 750t | Rino® 755t
Transferring Waypoints with Custom Symbols from BaseCamp to a Device
If you transfer a waypoint(s) with a custom symbol from BaseCamp to your device, the custom symbol does not transfer with the waypoint, even if the device has the same custom symbol.
You have to change the waypoint on the device itself to the custom symbol if you want it to reflect that symbol.
