Archiving a Track and Marking a Track as a Favorite on an Outdoor Handheld
You can archive a saved track, or mark a track as a favorite when managing your data on the handheld.
An Archived Track is created from the Current Track Log to free up more space for the Current Track to continue recording without losing any data. Archived Tracks save all of the information from the Current Track. Archived Tracks reside in a different location of the memory.
Marking a track as a favorite moves it from the archived section for easy access.
Dakota™ Handhelds
These steps apply to the Dakota 10 and 20.
Archiving a Track
From the main menu, select Track Manager.
Select a track.
Select Archive.
The track will now show under Archived Tracks.
Marking a Favorite
Select Archived Tracks.
Select an archived track.
Select Make Favorite.
This track will now show in the list under the Current Track.
eTrex® 20, 20x, 22x, 30, 30x, and 32x Handhelds
Archiving a Track
Press menu twice to access the main menu.
Select Track Manager.
Select a track.
Select Archive.
Marking a Favorite
eTrex Touch 25, 35, and 35t Handhelds
NOTE: The eTrex Touch 25, 35, and 35t record files in an activity format (FIT) by default. If you need the handheld to also record files as tracks (GPX), select > Setup > Activities > Advanced Setup > Output Format > Tracks (GPX/FIT).
Archiving a Track
Press to open the app drawer.
Select a track under Favorite Tracks.
Select .
Tap .
The track will now be moved under Archived Tracks.
Marking a Favorite
Select .
Tap .
This track will now show in the list under Favorite Tracks.
GPSMAP® 62, 64 and 65 Series Handhelds
These steps apply to the following GPSMAP handheld models:
These devices record FIT activities by default but can be set to record GPX tracks. For more details on changing the output format, refer to Advanced Recording Settings in your owner's manual.
Archiving a Track
Press MENU twice to access the main menu.
Select Saved Tracks.
Select a track.
Press Menu.
Select Archive.
Marking a Favorite
Press Menu.
Montana® 600 And 650 Handhelds
These steps apply to the Montana 600, 600t Camo, 650, and 650t.
Archiving a Track
Tap to open the app drawer.
Select a track.
Select Archive.
Marking a Favorite
Montana 610 and 680 Handhelds
These steps apply to the Montana 610, 610t Camo, 680, and 680t.
Archiving a Track
Select a track.
Select .
Tap .
Marking a Favorite
Select .
Tap .
Montana 700 Series Handhelds
These steps apply to the Montana 700, 700i, 710, 710i, 750i, and 760i.
These devices record FIT activities by default but can be set to record GPX tracks. For more details on changing the output format, refer to your owner's manual.
Archiving a Track
From the main menu, select Saved Tracks.
Select a track.
Select .
Tap .
Marking a Favorite
Select .
Tap .
Oregon® 450 and 550 Series Handhelds
These steps apply to the Oregon 450, 450t, 550, and 550t.
Archiving a Track
Select a track.
Select Archive.
Marking a Favorite
Oregon 600 Series Handhelds
These steps apply to the Oregon 600, 600t, 650, and 650t.
Archiving a Track
From the home screen, open the app drawer by swiping bottom to top in portrait mode or left to right in landscape mode.
Select .
Tap .
Marking a Favorite
Select .
Tap .
Oregon 700 Series Handhelds
These steps apply to the Oregon 700, 750, and 750t.
NOTE: The user interface on these devices is set to Activity Mode by default, but they can be changed to Classic Mode by going to the app drawer and selecting Setup > System > Mode. These devices also record files in an activity format (FIT) by default. If you need the handheld to record files as tracks (GPX), open the app drawer and select Setup > Recording > Advanced Setup > Output Format > Tracks (GPX/FIT).
Archiving a Track
Open the app drawer.
Activity Mode: Press .
Classic Mode: From the home screen, swipe bottom to top in portrait mode or left to right in landscape mode.
Select .
Tap .
Marking a Favorite
Select .
Tap .
Rino® 600 Series Handhelds
These steps apply to the Rino 610, 650, 650t, and 655t.
Archiving a Track
Select a track.
Select Archive.
Marking a Favorite
Rino 750, 750t, and 755t Handhelds
NOTE: The user interface on the Rino 750, 750t, and 755t is set to Classic Mode by default, but it can be changed to Activity Mode by going to the app drawer and selecting Setup > System > Mode. These devices also record files in an activity format (FIT) by default. If you need the handheld to record files as tracks (GPX), open the app drawer and select Setup > Recording > Advanced Setup > Output Format > Tracks (GPX/FIT).
Archiving a Track
Select .
Tap .
Marking a Favorite
Select .
Tap .
