Accessing Settings for Garmin Running Power Apps
To access the settings of a Connect IQ™ power app, you will need to use the Connect IQ Store app from the smartphone paired to your watch.
Accessing Connect IQ Settings
Open the Connect IQ Store app.
Select My Device.
If you have more than one Garmin watch you can switch the watch by touching
then touching Select a Device.
Select My Data Fields.
Select the Garmin Running Power app you would like to adjust.
Select Settings.
Once you have selected the desired options, select Save to send the changes to the watch.
