Pairing a zumo 220 with a Bluetooth headset
You can use your zumo with a Bluetooth headset or helmet by pairing them. Before you begin, set your headset to Find Me/Discoverable mode. If you are not sure how to do this, refer to the owner's manual or documentation that came with the device.
In order to connect to the zumo, the headset must support the hands-free profile and use Bluetooth version 1.1 or higher. Note: These are general guidelines, and do not guarantee compatibility.
Bluetooth should automatically be enabled on your device, if it is not use the following steps to enable Bluetooth:
- Touch Tools
- Touch Settings
- Touch Bluetooth
- Touch the box under Bluetooth
- Touch Enabled
- Touch Ok
Bluetooth will now be enabled on your device.
To pair and connect your headset/helmet with your device:
- Touch Tools
- Touch Settings
- Touch Bluetooth
- Touch Change/Add under Connections option
- Touch OK on the message that prompts you to set your headset/helmet to Find Me or Discoverable mode
- The device will search for and display a list of compatible Bluetooth devices in the area
- Touch the name of the desired headset/helmet from the list
- Touch OK
- Enter the passkey displayed, if prompted
A message should display that the Garmin device successfully paired with the headset. When your device and headset are within range of each other and have Bluetooth enabled, they will automatically connect.
