Sensors Not Showing Speed or Cadence in the Tacx Training App
If you have connected to a previously paired speed and/or cadence sensor and you are not seeing data from the sensors as you ride on your basic trainer, you need to make sure that you have selected the option "Use as Virtual Trainer" within the Tacx Training app.
Open the Tacx Training app.
Select Settings (bottom right).
Select Device Manager.
Under Other Devices select Use as Virtual Trainer.
Select the trainer that you are using.
You will now see sensor data through the app.
